* include/rtems/Makefile.am: Added termiostypes.h.
* libc/Makefile.am: Removed termiostypes.h.
* libc/termios.c: Changed include of "termiostypes.h" to
<rtems/termiostypes.h> since that is an RTEMS specific header file.
* libc/getcwd.c: Ensure _closedir(dir) is called even on
error exit from the routine.
* libc/termios.c, libc/termiostypes.h: Task driver driver model
and line discipline support from Thomas Doerfler
<Thomas.Doerfler@imd-systems.de>.
* libc/mount.c: Make sure there is space allocated for a device name
in the mount table entry.
* libc/mount.c (search_mt_for_mount_point): Deleted routine.
* libc/mount.c (Is_node_fs_root): Replacement for above that
accounts for the imaginary root node being returned by the
filesystem evaluation routine.
* libc/unmount.c (unmount): Account for imaginary root node
being returned and improved variable names to clarify code.
* libc/unmount.c (file_systems_below_this_mountpoint): Body of
routine replaced to account for imaginary root node being returned.
* libc/libio.c: Special treatment of O_NDELAY for Cygwin.
libc/utime.c, libc/write.c:
<rtems/XXX.h>.
* libc/ioman.c: Moved to libfs.
* libc/Makefile.am: Removed ioman.c as part of moving it to libfs.
* libc/base_fs.c: Removed include of imfs.h and reworded comment
to avoid being IMFS specific.
* libc/libio.h: Removed prototype of IMFS_ops since it should
not be in this file.
* libc/mount.c: Removed IMFS specific configuration information.
* libc/unmount.c: Removed include of imfs.h and reworded comment
* libc/Makefile.am: Added mallocfreespace.c.
* libc/mallocfreespace.c: New file based on work by Nick Simon
<Nick.SIMON@syntegra.bt.co.uk> which he included in malloc.c.
* libc/libcsupport.h: Added prototype for malloc_free_space().
* libc/fcntl.c: Do not require every filesystem to have an fcntl()
handler. Most fcntl() operations can be performed with no
filesystem support.
* ChangeLog: Corrected comment.
* libc/newlibc.c: Removed _A29K specific ifdef.
* libio.c: Added O_NONBLOCK to list of flags.
all APIs.
* libc/fs_null_handlers.c: Added missing rmnod entry.
* libc/isatty.c, libc/imfs_handlers_directory.c, libc/creat.c,
libc/imfs_directory.c: Fixed style issues.
* libc/eval.c: Ditto.
* libc/fcntl.c: Ditto.
* libc/fsync.c: Ditto.
* libc/ioctl.c: Ditto.
* libc/ioman.c: Ditto.
* libc/link.c: Ditto.
* libc/memfile.c: Ditto.
* libc/mknod.c: Ditto.
* libc/symlink.c: Ditto.
-4 = {d = -4, i = {0xc0100000, 0x0}} s=1 e=0x80 m=0x100000 (0x0900000)
-3 = {d = -3, i = {0xc0080000, 0x0}} s=1 e=0x80 m=0x080000 (0x0880000)
-2 = {d = -2, i = {0xc0000000, 0x0}} s=1 e=0x80 m=0x000000 (0x0800000)
-1 = {d = -1, i = {0xbff00000, 0x0}} s=1 e=0x7f m=0x000000 (0x0800000)
0 = {d = 0, i = {0x00000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x3ff00000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x40000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
3 = {d = 3, i = {0x40080000, 0x0}} s=0 e=0 m=0x080000 (0x0880000)
C4X
-4 = {d = -4, i = {0x01800000, 0x0}} s=1 e=1 m=0x800000 (0x1000000)
-3 = {d = -3, i = {0x01c00000, 0x0}} s=1 e=1 m=0xa00000 (0x1400000)
-2 = {d = -2, i = {0x00800000, 0x0}} s=1 e=0 m=0x800000 (0x1000000)
-1 = {d = -1, i = {0xff800000, 0x0}} s=1 e=0xff m=0x000000 (0x1000000)
0 = {d = 0, i = {0x80000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x00000000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x01000000, 0x0}} s=0 e=1 m=0x400000 (0x0800000)
3 = {d = 3, i = {0x01400000, 0x0}} s=0 e=1 m=0x600000 (0x0c00000)
4 = {d = 4, i = {0x02000000, 0x0}} s=0 e=2 m=0xXXXXXX (0x0000000)
0x1010 0000
0101 0000
0010 1002
the correct circumstances of DMA buffer size, serial
line interrupts, and ethernet interrupts the termios osend routine would
lock up waiting for the raw output buffer semaphore.
functionality to libc and update TODO.
ttyHead back link is set.
significant things:
and PowerPC
same code base.
Removed times() since the version in the C Library support code is
fine.
was made in the conversion of bcopy() to strncpy().
substantial upgrade of newlibc.c occurred. Now the user extension
data area is used rather than notepads and as many routines as possible
were split into other files further reducing the minimum footprint
of an RTEMS executable.
libio flags and external fcntl.h style flags.
a full mount table at initialization. This is the wrong place
to mount filesystems 2-n since no device drivers are initialized
yet.
readdir support. The next step is to add a mount table and configure
either the miniIMFS or the full IMFS at the application level.
process.
