* | Filesystem: PR1398: Fix lseek() mechanic | Sebastian Huber | 2012-05-11 | 1 | -53/+1 |
| | | | | | | | | | | | | According to POSIX the lseek() function shall not, by itself, extend the size of a file. Remove the size field of rtems_libio_t. A file has only one size but may have multiple open file descriptors. Thus a file size field in the file descriptor may lead to inconsistencies. New default handlers rtems_filesystem_default_lseek_file() and rtems_filesystem_default_lseek_directory(). | ||||
* | Filesystem: Remove per file descriptor semaphore | Sebastian Huber | 2012-05-04 | 1 | -24/+4 |
| | | | | | | | | | The per file descriptor semaphore (field of rtems_libio_t) is unused in RTEMS. There is a considerable memory overhead due to that. A semaphore needs roughly 124 bytes which is huge compared to the approximately 72 bytes for the file descriptor structure itself. Device drivers can create their own synchronization primitives in the open handler on demand. | ||||
* | networking: socket to/from file descriptor | Sebastian Huber | 2012-04-03 | 1 | -76/+0 |
| | | | | | | | | | | o Move rtems_bsdnet_fdToSocket() and rtems_bsdnet_makeFdForSocket() to "cpukit/libnetworking/rtems/rtems_syscall.c". o The rtems_bsdnet_makeFdForSocket() function is now static. o Check in rtems_bsdnet_fdToSocket() function that the file descriptor uses the socket handlers, otherwise an error status will be returned and errno set to ENOTSOCK. o New test libtests/syscall01. | ||||
* | Filesystem: Change type of ioctl_return | Sebastian Huber | 2012-04-03 | 1 | -3/+1 |
| | | | | | Change the ioctl_return type of rtems_libio_ioctl_args_t to match the ioctl() return value type. | ||||
* | Filesystem: Rename defines | Sebastian Huber | 2012-03-13 | 23 | -55/+100 |
| | | | | | | | | | | | | | | | o Removed RTEMS_LIBIO_PERMS_SEARCH. o Renamed RTEMS_LIBIO_PERMS_READ in RTEMS_FS_PERMS_READ. o Renamed RTEMS_LIBIO_PERMS_WRITE in RTEMS_FS_PERMS_WRITE. o Renamed RTEMS_LIBIO_PERMS_EXEC in RTEMS_FS_PERMS_EXEC. o Renamed RTEMS_LIBIO_FOLLOW_HARD_LINK in RTEMS_FS_FOLLOW_HARD_LINK. o Renamed RTEMS_LIBIO_FOLLOW_SYM_LINK in RTEMS_FS_FOLLOW_SYM_LINK. o Renamed RTEMS_LIBIO_MAKE in RTEMS_FS_MAKE. o Renamed RTEMS_LIBIO_EXCLUSIVE in RTEMS_FS_EXCLUSIVE. o Renamed RTEMS_LIBIO_ACCEPT_RESIDUAL_DELIMITERS in RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS. o Renamed RTEMS_LIBIO_REJECT_TERMINAL_DOT in RTEMS_FS_REJECT_TERMINAL_DOT. | ||||
* | Filesystem: New defaults fsync_h and fdatasync_h | Sebastian Huber | 2012-03-13 | 1 | -2/+2 |
| | | | | | | | New defaults rtems_filesystem_default_fsync_or_fdatasync() and rtems_filesystem_default_fsync_or_fdatasync_success() for fsync_h and fdatasync_h. The rtems_filesystem_default_fsync_or_fdatasync() sets now errno to EINVAL according to POSIX. | ||||
* | Filesystem: Read-only file system checks | Sebastian Huber | 2012-03-13 | 3 | -26/+40 |
| | | | | | | | o Make sure EROFS is indicated for write operations on a read-only file system. o Add error indication for read-only file systems in fchmod() and fchown() according to POSIX. | ||||
* | Filesystem: Reference counting for locations | Sebastian Huber | 2012-03-13 | 47 | -1781/+2200 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01. | ||||
* | 2012-02-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsépius | 2012-02-22 | 1 | -0/+2 |
| | | | | | * libcsupport/src/assocnamebad.c: Add #define INSIDE_ASSOC. | ||||
* | Added support functions for greedy heap allocation | Sebastian Huber | 2012-02-10 | 1 | -0/+37 |
| | | | | | | Various tests must check program paths that result due to failed memory allocations from the heap. To avoid tinkering with internal heap structures throughout the test code these functions should be used. | ||||
* | 2011-12-14 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-12-14 | 1 | -1/+1 |
| | | | | * libcsupport/src/termios_setinitialbaud.c: Fixed typo. | ||||
* | 2011-12-14 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-12-14 | 4 | -42/+30 |
| | | | | | | | | | * libcsupport/include/rtems/termiostypes.h, libcsupport/src/termios_baud2num.c, libcsupport/src/termios_baudtable.c, libcsupport/src/termios_num2baud.c, libcsupport/src/termios_setinitialbaud.c: Added const qualifier to baud associations. Fixed integer types. | ||||
* | 2011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-13 | 1 | -0/+4 |
| | | | | | | * configure.ac: Check for getrusage.h decl. * libcsupport/src/getrusage.c: Apply HAVE_DECL_GETRUSAGE (Missing prototypes). | ||||
* | 2011-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-08 | 1 | -1/+1 |
| | | | | | * libcsupport/src/termios.c: Make rtems_termios_refill_transmitter static. | ||||
* | 2011-12-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-07 | 1 | -0/+1 |
| | | | | | * libcsupport/src/sup_fs_is_separator.c: Include <rtems/libio_.h> (Missing protypes). | ||||
* | 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-06 | 1 | -2/+3 |
| | | | | | * libcsupport/src/pipe.c: Include <unistd.h>. Include <rtems/pipe.h>. | ||||
* | 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-06 | 3 | -3/+3 |
| | | | | | | * libcsupport/src/flockfile.c, libcsupport/src/ftrylockfile.c, libcsupport/src/funlockfile.c: Add __attribute__((unused)) to unused function parameters. | ||||
* | 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-06 | 1 | -1/+8 |
| | | | | * libcsupport/src/envlock.c: Build conditionally. | ||||
* | 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-06 | 1 | -1/+1 |
| | | | | | * libcsupport/src/envlock.c: Rename define ENVLOCK_DEDIDCATED_MUTEX into ENVLOCK_DEDICATED_MUTEX (Typo). | ||||
* | 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-06 | 1 | -4/+2 |
| | | | | | * libcsupport/src/malloc_sbrk_helpers.c: Make malloc_sbrk_initialize, malloc_sbrk_extend_and_allocate static. | ||||
* | 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-05 | 2 | -6/+2 |
| | | | | | * libcsupport/src/chown.c, libcsupport/src/lchown.c: Include <unistd.h>. Cleanup included headers. | ||||
* | 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-05 | 1 | -1/+1 |
| | | | | * libcsupport/src/termios.c: Remove unnecessary cast. | ||||
* | 2011-12-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-03 | 1 | -8/+8 |
| | | | | * libcsupport/src/termios.c: Make FL_* defines unsigned. | ||||
* | 2011-12-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-03 | 3 | -7/+3 |
| | | | | | | | * libcsupport/src/getgid.c: Include <unistd.h>. * libcsupport/src/setgid.c: Include <unistd.h>. * libcsupport/src/getpgrp.c: Include <unistd.h>. Remove unnecessary includes. | ||||
* | 2011-12-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-01 | 1 | -2/+2 |
| | | | | * libcsupport/src/open.c: Use va_arg(..., mode_t) to retrieve mode. | ||||
* | 2011-11-10 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-11-10 | 1 | -6/+3 |
| | | | | | | | | | | | | | PR 1924/cpukit * sapi/include/rtems/config.h: New fields stack_space_size, unified_work_area, and stack_allocator_avoids_work_space in rtems_configuration_table. * sapi/include/confdefs.h: Removed rtems_unified_work_area (this is now part of the Configuration). Separate work space and stack space estimate. Added CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE configuration option. * libmisc/shell/main_wkspaceinfo.c, score/src/wkspace.c, libcsupport/src/malloc_initialize.c: Update due to API changes. | ||||
* | 2011-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-30 | 1 | -3/+0 |
| | | | | * libcsupport/src/newlibc_exit.c: Don't undef __USE_INIT_FINI__. | ||||
* | 2011-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-23 | 1 | -2/+2 |
| | | | | * libcsupport/src/utimes.c (utimes): Remove casts to time_t. | ||||
* | 2011-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-18 | 1 | -6/+6 |
| | | | | | * libcsupport/include/rtems/libio.h, libcsupport/src/termios.c: Use size_t for sizes. | ||||
* | 2011-10-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-11 | 1 | -1/+1 |
| | | | | | | * libcsupport/src/termios.c, libcsupport/include/rtems/termiostypes.h (rtems_termios_puts): Use size_t for buffer size. | ||||
* | 2011-10-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-10 | 1 | -2/+2 |
| | | | | * libcsupport/src/termios.c: Remove meaningless typecast. | ||||
* | 2011-08-15 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-08-15 | 1 | -1/+3 |
| | | | | | | * libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Added init/fini array support for ARM EABI. The __libc_init_array() and __libc_fini_array() functions are provided by Newlib. | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 8 | -16/+8 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | 2011-07-22 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-07-22 | 9 | -23/+14 |
| | | | | | | | | | | | PR 1839/filesystem * libcsupport/include/rtems/libio_.h, libcsupport/src/fchdir.c, libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c, libcsupport/src/fsync.c, libcsupport/src/ftruncate.c, libcsupport/src/read.c, libcsupport/src/readv.c, libcsupport/src/write.c, libcsupport/src/writev.c: Some calls did not return proper status for permission errors or incorrectly permissions at all. | ||||
* | 2011-07-19 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-07-19 | 1 | -4/+1 |
| | | | | | | PR 1838/filesystem * libcsupport/src/fchmod.c: fchmod() does not need a writeable file descriptor. | ||||
* | 2011-07-18 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-07-18 | 1 | -15/+15 |
| | | | | | * libcsupport/src/malloc_report_statistics_plugin.c: Fixed format specifiers. | ||||
* | 2011-07-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-01 | 1 | -3/+5 |
| | | | | | | | * libcsupport/src/malloc_initialize.c: After discussion with Till Straumann, revert the change from r1.12 to r1.13. This broke BSPs with sbrk() support once the libbsp sbrk() framework was enhanced. psim runs now. | ||||
* | 2011-06-17 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-06-17 | 1 | -2/+2 |
| | | | | | | * libcsupport/include/rtems/libio.h, cpukit/libcsupport/src/termios.c: Added const qualifier to rtems_termios_enqueue_raw_characters(). Removed superfluous cast. | ||||
* | 2011-04-21 Jennifer Averett <Jennifer.Averett@OARcorp.com | Jennifer Averett | 2011-04-21 | 2 | -2/+2 |
| | | | | | | | | | | | | | PR 1777/cpukit * libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c, score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c, score/include/rtems/score/coremutex.h, score/include/rtems/score/thread.h, score/inline/rtems/score/thread.inl, score/src/heapfree.c, score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c: Consolidated access to _Thread_Dispatch_disable_level. * score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c: New files. | ||||
* | 2011-04-15 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-04-15 | 1 | -1/+1 |
| | | | | * libcsupport/src/ioctl.c: Fixed integer type. | ||||
* | 2011-03-03 Chris Johns <chrisj@rtems.org> | Chris Johns | 2011-03-03 | 1 | -3/+15 |
| | | | | | | * libcsupport/src/mknod.c, libfs/src/rfs/rtems-rfs-inode.c: PR 1749. Fix the incorrect handling of the file type in the mode value to reject invalid types as per the standard. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 1 | -55/+0 |
| | | | | | | | | * libcsupport/src/sleep_noposix.c: Remove. * libcsupport/Makefile.am: Reflect changes above. * posix/src/sleep.c, posix/src/usleep.c: Remove. * posix/Makefile.am: Reflect changes above. * configure.ac: Error out if libc doesn't provide sleep, usleep. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 1 | -21/+0 |
| | | | | | | * libcsupport/src/creat.c: Remove. * libcsupport/Makefile.am: Reflect changes above. * configure.ac: Error out if libc doesn't provide creat. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 7 | -572/+0 |
| | | | | | | | | | | | * libcsupport/src/opendir.c, libcsupport/src/closedir.c, libcsupport/src/readdir.c, libcsupport/src/rewinddir.c, libcsupport/src/scandir.c, libcsupport/src/seekdir.c, libcsupport/src/telldir.c: Remove. * libcsuppport/Makefile.am: Reflect changes above. * configure.ac: Error out if libc doesn't provide opendir, closedir, readdir, rewinddir, scandir, seekdir, telldir. | ||||
* | 2011-02-17 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-17 | 1 | -0/+45 |
| | | | | | | | * libcsupport/src/rtems_heap_extend.c: New file. * libcsupport/Makefile.am: Reflect change from above. * libcsupport/include/rtems/malloc.h: Declare rtems_heap_extend(). * score/include/rtems/score/heap.h: Documentation. | ||||
* | 2011-02-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-01 | 1 | -1/+1 |
| | | | | * libcsupport/src/printk.c: Fix typo. | ||||
* | 2011-01-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-01-04 | 1 | -1/+6 |
| | | | | | | * libcsupport/src/error.c: Scheduler Simulator compilation always defines __RTEMS_VIOLATE_KERNEL_VISIBILITY__. So avoid redefinition warning. | ||||
* | 2010-11-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-11-30 | 1 | -20/+3 |
| | | | | | | | * libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Revert previous commit due to too many broken linker command files. The HAVE_INITFINI_ARRAY is defined for nearly all targets by Newlib, but only few linker command files respect this. | ||||
* | 2010-11-29 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-11-29 | 1 | -3/+20 |
| | | | | | * libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Added support for .preinit_array, .init_array and .fini_array sections. | ||||
* | 2010-11-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-11-16 | 1 | -0/+2 |
| | | | | | PR 1717/cpukit * libcsupport/src/gxx_wrappers.c: Free memory on error. |
