path: root/cpukit/libcsupport/src/writev.c (follow)
* Filesystem: Add readv/writev handlersSebastian Huber2013-12-201-20/+1
| | | | | | | | | The readv() and writev() support was implemented in terms of multiple calls to the read and write handlers. This imposes a problem on device files which use an IO vector as single request entity. For example a low-level network device (e.g. BPF(4)) may use an IO vector to create one frame from multiple protocol layers each with its own IO vector entry.
* libcsupport: Add and use rtems_libio_iovec_eval()Sebastian Huber2013-12-201-82/+16
* Filesystem: PR1255: Move offset update to handlersSebastian Huber2012-05-151-1/+0
| | | | | | | It is now the responsibility of the read() and write() handler to update the offset field of the IO descriptor (rtems_libio_t). This change makes it possible to protect the IO descriptor from concurrent access by per file locks.
* 2011-07-22 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-07-221-2/+2
| | | | | | | | | | | PR 1839/filesystem * libcsupport/include/rtems/libio_.h, libcsupport/src/fchdir.c, libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c, libcsupport/src/fsync.c, libcsupport/src/ftruncate.c, libcsupport/src/read.c, libcsupport/src/readv.c, libcsupport/src/write.c, libcsupport/src/writev.c: Some calls did not return proper status for permission errors or incorrectly permissions at all.
* 2010-08-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-08-251-4/+5
| | | | | | | Coverity Id 93/NO_EFFECT Coverity Id 94/NO_EFFECT * libcsupport/src/readv.c, libcsupport/src/writev.c: size_t is unsigned so it is useless to check for < 0.
* 2010-07-16 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-07-151-1/+5
| | | | | | | | | | | | | | | | | | | | | * libcsupport/include/rtems/libio.h: Removed file_info and handlers fields in rtems_libio_t. * libcsupport/src/close.c, libcsupport/src/fcntl.c, libcsupport/src/fdatasync.c, libcsupport/src/fstat.c, libcsupport/src/fsync.c, libcsupport/src/ftruncate.c, libcsupport/src/getdents.c, libcsupport/src/ioctl.c, libcsupport/src/libio_sockets.c, libcsupport/src/lseek.c, libcsupport/src/open.c, libcsupport/src/read.c, libcsupport/src/readv.c, libcsupport/src/write.c, libcsupport/src/writev.c, libfs/src/devfs/devclose.c, libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c, libfs/src/devfs/devwrite.c libfs/src/dosfs/msdos_dir.c libfs/src/dosfs/msdos_file.c libfs/src/imfs/deviceio.c libfs/src/imfs/imfs_directory.c libfs/src/imfs/imfs_fifo.c libfs/src/imfs/memfile.c libfs/src/nfsclient/src/nfs.c libfs/src/rfs/rtems-rfs-rtems-file.c libfs/src/rfs/rtems-rfs-rtems.h libnetworking/lib/ftpfs.c: Reflect changes above.
* 2010-07-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-011-3/+0
| | | | | | | * libcsupport/src/_rename_r.c, libcsupport/src/getdents.c, libcsupport/src/unlink.c, libcsupport/src/utime.c, libcsupport/src/writev.c: Remove remaining checks for missing handlers.
* Whitespace removal.Ralf Corsepius2009-11-291-3/+3
* Convert using "bool".Ralf Corsepius2008-09-011-4/+4
* 2007-09-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-09-241-0/+126
PR 1262/filesystem * libcsupport/Makefile.am, libnetworking/libc/herror.c, libnetworking/libc/res_send.c, libnetworking/sys/uio.h, telnetd/Makefile.am, telnetd/README, telnetd/preinstall.am, telnetd/pty.c, telnetd/telnetd.c: Add support for readv() and writev() including documentation and test case. * libcsupport/src/readv.c, libcsupport/src/writev.c: New files.
