* | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | 2015-10-26 | 1 | -1/+1 |
* | libcsupport: Doxygen Enhancement Task #3 | Mathew Kallada | 2012-12-08 | 1 | -2/+7 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992210 | ||||
* | Add __attribute__((unused)) to function arguments. | Ralf Corsepius | 2009-09-15 | 1 | -1/+1 |
* | 2007-03-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-26 | 1 | -0/+40 |
* libcsupport/src/assoc.c, libcsupport/src/libio.c, libcsupport/src/write.c: Split files to shrink minimum.exe. Hopefully this will not be deemed necessary to commit to the 4.7 branch. * libcsupport/src/assoclocalbyname.c, libcsupport/src/assoclocalbyremote.c, libcsupport/src/assoclocalbyremotebitfield.c, libcsupport/src/assocnamebylocal.c, libcsupport/src/assocnamebylocalbitfield.c, libcsupport/src/assocnamebyremote.c, libcsupport/src/assocnamebyremotebitfield.c, libcsupport/src/assocptrbylocal.c, libcsupport/src/assocptrbyname.c, libcsupport/src/assocptrbyremote.c, libcsupport/src/assocremotebylocal.c, libcsupport/src/assocremotebylocalbitfield.c, libcsupport/src/assocremotebyname.c, libcsupport/src/libio_init.c, libcsupport/src/write_r.c: New files. |
