#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3904.
The previous vprintk() implementation had a questionable licence header,
lacks support for the 'z' and 'j' format specifiers, is not robust
against invalid format specifiers, uses a global variable for output.
Replace it with a stripped down version of the FreeBSD kernel kvprintf()
function.
The new implementation allows a low overhead rtems_snprintf() if
necessary.
Update #3199.
Close #3216.
of this patch set.
http://www.google-melange.com/gci/task/view/google/gci2012/7992211
This reduces code size and provides a function similar to fputc().
Changed type of boolean variables to bool. Use unsigned integer type
for radix and width parameters.
* score/src/wkspace.c: Removed work space area consistency checks.
* libblock/include/rtems/ide_part_table.h: Functions are now
deprecated.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/calloc.c,
libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_initialize.c,
libcsupport/src/malloc_report_statistics_plugin.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c,
rtems/inline/rtems/rtems/region.inl: Update for heap API changes.
2009-09-14 Christian Mauderer <christian.mauderer@embedded-brains.de>
* libcsupport/src/vprintk.c: Fixed warnings. Print nothing in case the
pointer to the string is NULL.
* libcsupport/Makefile.am, libcsupport/src/printk.c: Restructure to
make analysis and coverage easier. Now 100% covered.
* libcsupport/src/vprintk.c: New file.
