path: root/cpukit/libcsupport/src/utsname.c (follow)
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-1/+1
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* Works now.Joel Sherrill1999-11-161-19/+12
| | | | | Removed times() since the version in the C Library support code is fine.
* Updated version string.Joel Sherrill1999-04-151-2/+1
* comment clean upJoel Sherrill1996-05-291-2/+1
* removed all ifdef's on NOT_IMPLEMENTED.Joel Sherrill1996-05-291-4/+0
* These files have been modified in the initial pass at getting the portionJoel Sherrill1996-05-221-0/+1
| | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have.
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+1
* moved to new development machine and went to gcc 2.7.0Joel Sherrill1995-10-061-1/+1
* posix support initially addedJoel Sherrill1995-09-261-0/+60
