path: root/cpukit/libcsupport/src/unmount.c (follow)
* Canonicalize config.h includeSebastian Huber2020-04-161-2/+2
* libcsupport: Doxygen enhancement GCI task #6Alex Ivanov2012-12-111-7/+13
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992212
* Filesystem: Use transient eventSebastian Huber2012-10-301-6/+3
* Filesystem: Rename functionSebastian Huber2012-10-071-1/+1
| | | | | | Rename rtems_filesystem_location_is_root() into rtems_filesystem_location_is_instance_root() to distinguish this from the file system root directory of the current task environment.
* Filesystem: Wait for unmount() to finishSebastian Huber2012-05-291-8/+41
* Filesystem: Move operations to mount table entrySebastian Huber2012-05-151-1/+4
| | | | | | | | | | | The scope of the file system operations is the file system instance. The scope of the file system node handlers is the file location. The benefit of moving the operations to the mount table entry is a size reduction of the file location (rtems_filesystem_location_info_t). The code size is slightly increased due to additional load instructions. Restructure rtems_filesystem_mount_table_entry_t to improve cache efficiency.
* Filesystem: Rename definesSebastian Huber2012-03-131-1/+1
| | | | | | | | | | | | | | | o Removed RTEMS_LIBIO_PERMS_SEARCH. o Renamed RTEMS_LIBIO_PERMS_READ in RTEMS_FS_PERMS_READ. o Renamed RTEMS_LIBIO_PERMS_WRITE in RTEMS_FS_PERMS_WRITE. o Renamed RTEMS_LIBIO_PERMS_EXEC in RTEMS_FS_PERMS_EXEC. o Renamed RTEMS_LIBIO_FOLLOW_HARD_LINK in RTEMS_FS_FOLLOW_HARD_LINK. o Renamed RTEMS_LIBIO_FOLLOW_SYM_LINK in RTEMS_FS_FOLLOW_SYM_LINK. o Renamed RTEMS_LIBIO_MAKE in RTEMS_FS_MAKE. o Renamed RTEMS_LIBIO_EXCLUSIVE in RTEMS_FS_EXCLUSIVE. o Renamed RTEMS_LIBIO_ACCEPT_RESIDUAL_DELIMITERS in RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS. o Renamed RTEMS_LIBIO_REJECT_TERMINAL_DOT in RTEMS_FS_REJECT_TERMINAL_DOT.
* Filesystem: Reference counting for locationsSebastian Huber2012-03-131-132/+23
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01.
* 2010-07-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-041-2/+1
| | | | | | | | | | | | | | | | * libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c, libcsupport/src/__times.c, libcsupport/src/libio_init.c, libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c, libcsupport/src/mount.c, libcsupport/src/rewinddir.c, libcsupport/src/seekdir.c, libcsupport/src/telldir.c, libcsupport/src/unmount.c, libfs/src/dosfs/fat.c, libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c, libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c, libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c, telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* 2010-07-01 Jennifer Averett <Jennifer.Averett@OARcorp.com>Jennifer Averett2010-07-011-11/+0
| | | | | | | | | | | | | | | | | | | | | * libcsupport/src/chdir.c, libcsupport/src/chmod.c, libcsupport/src/chown.c, libcsupport/src/close.c, libcsupport/src/eval.c, libcsupport/src/fchdir.c, libcsupport/src/fchmod.c, libcsupport/src/fchown.c, libcsupport/src/fcntl.c, libcsupport/src/fdatasync.c, libcsupport/src/freenode.c, libcsupport/src/fstat.c, libcsupport/src/fsync.c, libcsupport/src/ftruncate.c, libcsupport/src/ioctl.c, libcsupport/src/link.c, libcsupport/src/lseek.c, libcsupport/src/mknod.c, libcsupport/src/mount.c, libcsupport/src/open.c, libcsupport/src/read.c, libcsupport/src/readlink.c, libcsupport/src/readv.c, libcsupport/src/rmdir.c, libcsupport/src/stat.c, libcsupport/src/statvfs.c, libcsupport/src/symlink.c, libcsupport/src/unlink.c, libcsupport/src/unmount.c, libcsupport/src/write.c: Removed filesystem checks for NULL methods checks from the main posix rountines. These are now required to have at a miminum default routines in the tables.
* 2010-07-01 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-07-011-46/+11
| | | | | | | | | | | | * libcsupport/include/rtems/libio_.h: Removed rtems_filesystem_mount_table_control. * libcsupport/include/rtems/libio.h, libcsupport/src/mount-mgr.c, libcsupport/src/mount.c libcsupport/src/statvfs.c, libcsupport/src/unmount.c, libmisc/shell/main_mount.c: Documentation. Removed rtems_filesystem_mounts_first() and rtems_filesystem_mounts_next(). Added rtems_filesystem_mount_iterate(). Changed return type of rtems_filesystem_iterate(). Removed rtems_filesystem_nodes_equal().
* 2010-06-10 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-06-101-11/+0
| | | | | * libcsupport/src/unmount.c: Removed obsolete declarations. Fixed invalid memory free.
* 2010-05-31 Chris Johns <chrisj@rtems.org>Chris Johns2010-05-311-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/Makefile.am: Add mount-mgr.c. * libcsupport/src/mount-mgr.c: New. * include/rtems/fs.h: Added rtems_filesystem_location_mount. * libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New mount interface. It is similar to Linux. * libcsupport/include/rtems/libio_.h: Remove the init_fs_mount_table call. * libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use the new mount call. Remove setting the root node in the global pathloc. Mount does this now. * libcsupport/src/privateenv.c: Remove the hack to set the root mount table entry in the environment. * libcsupport/src/unmount.cL Free the target string. * libblock/src/bdpart-mount.c: New mount API. * libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c, libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c, libfs/src/imfs/miniimfs_init.c, libfs/src/nfsclient/src/librtemsNfs.h, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h, libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h, libnetworking/rtems/tftp.h: New mount_h API. * libfs/src/devfs/devfs_eval.c: Local include of extern ops. * libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount me call and fixed the initialisation to happen when mounting. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount filesystem files. * libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to the new mount table values. * libmisc/shell/main_mount_ftp.c, libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c, libmisc/shell/main_mount_tftp.c: Removed. * libmisc/shell/main_mount.c: Use the new mount API. Also access the file system table for the file system types. * libnetworking/lib/tftpDriver.c: Updated to the new mount API. Fixed to allow mounting from any mount point. Also can now have more than file system mounted. * sapi/include/confdefs.h: Add file system configuration support.
* Add __attribute__((unused)) to function arguments.Ralf Corsepius2009-09-151-2/+2
* 2009-06-12 Chris Johns <chrisj@rtems.org>Chris Johns2009-06-121-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c: Update comments. * libblock/src/bdpart.c, libblock/src/ide_part_table.c: Get the device from the rdev field of the stat buf. * libcsupport/include/rtems/libio.h: Add a path length to evalpath handler. Add parent locations to rmmod and unlink handlers. * libcsupport/include/rtems/libio_.h: Add a path length to rtems_filesystem_evaluate_path. Add rtems_filesystem_evaluate_relative_path, rtems_filesystem_dirname, and rtems_filesystem_prefix_separators. Remove rtems_filesystem_evaluate_parent. * libcsupport/src/base_fs.c, libcsupport/src/chdir.c, libcsupport/src/chmod.c, libcsupport/src/chown.c, libcsupport/src/chroot.c, libcsupport/src/fchdir.c, libcsupport/src/link.c, libcsupport/src/mount.c, libcsupport/src/open.c, libcsupport/src/privateenv.c, libcsupport/src/readlink.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devstat.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/ioman.c, libfs/src/pipe/pipe.c, libmisc/fsmount/fsmount.c, libnetworking/lib/ftpfs.c: Add the length parameter to the eval call. * libcsupport/src/eval.c: Add rtems_filesystem_prefix_separators, rtems_filesystem_dirname, rtems_filesystem_evaluate_relative_path. Add the length parameter to the eval call. * libcsupport/src/rmdir.c: Find the parent pathloc then the node pathloc from that node. Remove the call to find the parent given the node pathloc. * libcsupport/src/stat.c: Add the length parameter to the eval call. Set the device into the rdev field. * libcsupport/src/unlink.c: Find the parent pathloc then the node pathloc from that node. Remove the call to find the parent given the node pathloc. * libfs/src/dosfs/fat.c, libfs/src/dosfs/msdos_format.c: Get the disk device number from the stat rdev field. * libfs/src/dosfs/msdos.h: Add the length parameter to the eval call. Add the parent pathloc to the rmnod handler. * libfs/src/dosfs/msdos_dir.c: Add the parent pathloc to the rmnod handler. * libfs/src/dosfs/msdos_eval.c: Add the length parameter to the eval and token call. * libfs/src/imfs/imfs_directory.c: Add the parent pathloc to the rmnod handler. * libfs/src/imfs/imfs_fchmod.c: Do not test the mode flags for only the allowed flags. Add the missing flags spec'ed in the POSIX standard. * libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_rmnod.c, libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/memfile.c: Add the parent node. Currently ignored in the IMFS. * libfs/src/imfs/imfs_stat.c: Return the device number in the rdev field. * libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_symlink.c : Add the length parameter to the token call. * libfs/src/nfsclient/src/nfs.c: Add the length parameter to the eval call and parent node to the rmnod and unlink command. * libmisc/shell/internal.h: Remove the libc mounter decl to make public. * libmisc/shell/main_mount.c: Add support for hooking external mount support for new file systems. * libmisc/shell/shell.h: Add helper functions for the mount command.
* Convert using "bool".Ralf Corsepius2008-09-011-5/+5
* 2008-07-03 Chris Johns <chrisj@rtems.org>Chris Johns2008-07-031-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * cpukit/libcsupport/include/chain.h: Removed. Use the SAPI interface that is supported. * cpukit/libcsupport/Makefile.am, cpukit/libcsupport/preinstall.am: Remove chain.h header references. * cpukit/sapi/include/rtems/chain.h, cpukit/sapi/inline/rtems/chain.inl: New. A supported chains interface. * cpukit/sapi/Makefile.am, cpukit/sapi/preinstall.am: Updated to include the new chains interface. * cpukit/libfs/src/imfs/imfs.h, cpukit/libfs/src/imfs/imfs_creat.c, cpukit/libfs/src/imfs/imfs_debug.c, cpukit/libfs/src/imfs/imfs_directory.c, cpukit/libfs/src/imfs/imfs_fsunmount.c, cpukit/libfs/src/imfs/imfs_getchild.c, cpukit/libfs/src/imfs/imfs_load_tar.c, cpukit/libfs/src/imfs/imfs_rmnod.c, cpukit/libfs/src/imfs/memfile.c, cpukit/libfs/src/nfsclient/src/nfs.c, cpukit/libcsupport/include/rtems/libio.h, cpukit/libcsupport/src/malloc_deferred.c, cpukit/libcsupport/src/mount.c, cpukit/libcsupport/src/privateenv.c, cpukit/libcsupport/src/unmount.c: Change to the new chains interface. * cpukit/libcsupport/src/malloc_boundary.c: Remove warning.
* Remove stray white spaces.Ralf Corsepius2004-04-181-10/+10
* Remove stray white spaces.Ralf Corsepius2004-04-151-2/+0
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libblock/include/rtems/bdbuf.h: Include <rtems/chain.h> instead of <chain.h>. * libblock/include/rtems/ide_part_table.h: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/malloc.c: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/mount.c: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/unmount.c: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs.h: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs_directory.c: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs_load_tar.c: Include <rtems/chain.h> instead of <chain.h>. * sapi/include/confdefs.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * sapi/include/confdefs.h: Include <rtems/console.h> instead of <console.h>. * libfs/src/imfs/imfs_load_tar.c: Include <rtems/imfs.h> instead of <imfs.h>. * libmisc/shell/cmds.c: Include <rtems/imfs.h> instead of <imfs.h>. * libmisc/fsmount/fsmount.c: Include <rtems/imfs.h> instead of <imfs.h>. * sapi/include/confdefs.h: Include <rtems/imfs.h> instead of <imfs.h>. * itron/src/can_wup.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/chg_pri.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/dis_dsp.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ena_dsp.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/eventflags.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/exd_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ext_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/fmempool.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/frsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/get_tid.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itronintr.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itronsem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itrontime.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/mbox.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/mboxtranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/msgbuffer.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/msgbuffertranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/network.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/port.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/prcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/prcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/preq_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/psnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rel_wai.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rot_rdq.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sig_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/slp_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/snd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/snd_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sta_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sus_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sysmgmt.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/task.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ter_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/trcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/trcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/tslp_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/tsnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/twai_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/vmempool.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/wai_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/wup_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/rtems/config.h: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/confdefs.h: Include <rtems/itron.h> instead of <itron.h>. * sapi/src/itronapi.c: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/confdefs.h: Include <rtems/rtc.h> instead of <rtc.h>. * sapi/include/confdefs.h: Include <rtems/timerdrv.h> instead of <timerdrv.h>.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/chain.h, include/clockdrv.h, include/console.h, include/iosupp.h, include/rtc.h, include/spurious.h, include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h, include/rtems/termiostypes.h, include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h, include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c, src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c, src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c, src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c, src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c, src/fcntl.c, src/fdatasync.c, src/fpathconf.c, src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c, src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c, src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c, src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c, src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c, src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c, src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c, src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c, src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c, src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c, src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c, src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c, src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for license changed.
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-6/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/libio_.h: Remove set_errno_and_return_minus_one. * libc/cfsetispeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/cfsetospeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chown.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chroot.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/closedir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/eval.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fdatasync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fpathconf.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fstat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fsync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ftruncate.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/getdents.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ioctl.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/link.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/lseek.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/mknod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/open.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/read.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/readlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/rmdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/stat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/symlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/tcsetattr.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/telldir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname_r.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unmount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/utime.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/write.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one.
* 2001-10-25 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill2001-10-251-88/+116
| | | | | | | * libc/unmount.c: Primarily restructuring and clean up to address procedures which did not do what their name implied. Also addressed problem situation where unmount fails and the filesystem was inconsistent. The mounted filesystem could have been left hanging.
* 2001-10-17 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill2001-10-171-2/+5
| | | | | | | | | | | | | | | | * These changes were discussed and reviewed by many people but the primary people were Jennifer Averett <jennifer@OARcorp.com> and Eugeny Mints <jack@oktet.ru>. * libc/utime.c: Add missing call to rtems_filesystem_freenode() at verification that utime is supported by the filesystem. * libc/link.c: Remove calls to freenode when the node was not successfully allocated. * libc/unmount.c: In the method file_systems_below_this_mountpoint() added calls to correctly free fs_root_loc when a failure occurs. * libc/open.c: Add freenode calls upon failure. * libc/open.c, lib/libc/close.c: (PENDING -- NOT INCLUDED THIS TIMER) Modifications the move the freenode from open() to close() (also part of this patch) are pending further discussion.
* 2001-01-25 Fernando Ruiz <fernando.ruiz@ctv.es>Joel Sherrill2001-01-251-1/+0
| | | | | | | | | | * Alternate email is correo@fernando-ruiz.com * libc/privateenv.c: New file. * include/rtems/libio_.h, libc/Makefile.am, libc/base_fs.c, libc/unmount.c: Moved default umask, current working directory, root, and links followed count into a structure "user environment" that can then be treated as a unit. This enable giving unique copies of these to individual threads or collection of threads.
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+4
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-061-1/+0
| | | | | | * libc/mallocfreespace.c: Name of routine is rtems_region_get_information() NOT region_get_information(). * libc/unmount.c: Removed unused variable.
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-171-58/+35
| | | | | | | | | | | * libc/mount.c (search_mt_for_mount_point): Deleted routine. * libc/mount.c (Is_node_fs_root): Replacement for above that accounts for the imaginary root node being returned by the filesystem evaluation routine. * libc/unmount.c (unmount): Account for imaginary root node being returned and improved variable names to clarify code. * libc/unmount.c (file_systems_below_this_mountpoint): Body of routine replaced to account for imaginary root node being returned.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-251-5/+0
| | | | | | | | | | | | * libc/ioman.c: Moved to libfs. * libc/Makefile.am: Removed ioman.c as part of moving it to libfs. * libc/base_fs.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific. * libc/libio.h: Removed prototype of IMFS_ops since it should not be in this file. * libc/mount.c: Removed IMFS specific configuration information. * libc/unmount.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-2/+2
| | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-10/+2
* Added code to correctly free any allocated space during the evaluationJennifer Averett1999-10-251-0/+1
| | | | process.
* Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1999-10-121-11/+6
| | | | | places to make sure memory allocated for filesystem specifif nodes gets freed.
* Added call to freenod to let each filesystem free its own internalJoel Sherrill1999-10-121-5/+19
| | | | node used to manage file access.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+214
