path: root/cpukit/libcsupport/src/unixlibc.c (unfollow)
2001-01-082001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-0/+10
1997-03-10added include of rtems.h so the proper macro definitions would be present.Joel Sherrill1-0/+2
1996-09-18dummy function added to satisfy ANSIJoel Sherrill1-0/+10
1995-10-06fixed missing CVS IDsJoel Sherrill1-0/+4
