* | 2001-08-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-08-17 | 1 | -0/+17 |
| | | | | | | | | * include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX is defined on GNU/Linux (RedHat 6.2 distribution). * libc/unixlibc.c: Added stubs for rtems_io_register_name() and rtems_io_lookup_name() so UNIX port would compile the IO manager sptest that registers /dev/null. | ||||
* | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-08 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | ||||
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -0/+10 |
| | | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | ||||
* | added include of rtems.h so the proper macro definitions would be present. | Joel Sherrill | 1997-03-10 | 1 | -0/+2 |
* | dummy function added to satisfy ANSI | Joel Sherrill | 1996-09-18 | 1 | -0/+10 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -0/+4 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+7 |
