2001-01-08 | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | |||||
2000-06-14 | *** empty log message *** | Joel Sherrill | 1 | -2/+0 | |
1999-11-17 | Updated copyright notice. | Joel Sherrill | 1 | -2/+1 | |
1999-11-16 | Added. | Joel Sherrill | 1 | -3/+3 | |
1999-10-01 | Addition of more functionality by Eric Norum to support GNU readline. | Joel Sherrill | 1 | -5/+3 | |
1999-06-11 | Added local prototype of ioctl() to avoid requiring sys/ioctl.h. | Joel Sherrill | 1 | -1/+3 | |
1999-03-16 | Use proper include for libio.h. | Joel Sherrill | 1 | -1/+1 | |
1998-11-23 | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1 | -7/+14 | |
overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | |||||
1998-05-22 | Added tcdrain(), cfgetospeed(0, cfsetospeed(), cfgetispeed(), and | Joel Sherrill | 1 | -0/+26 | |
cfsetispeed(). |
