* | Remove redundant includes. | Ralf Corsepius | 2010-08-03 | 1 | -3/+1 |
* | 2010-07-30 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 2010-08-02 | 1 | -0/+32 |
PR 1645/cpukit * libcsupport/src/getuid.c: Moved setuid() routine to its own file. * libcsupport/src/setuid.c: New file with setuid() routine. * libcsupport/src/seteuid.c: New file with seteuid() routine. |
