path: root/cpukit/libcsupport/src/setgid.c (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* 2011-12-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-031-0/+1
| | | | | | | * libcsupport/src/getgid.c: Include <unistd.h>. * libcsupport/src/setgid.c: Include <unistd.h>. * libcsupport/src/getpgrp.c: Include <unistd.h>. Remove unnecessary includes.
* 2010-08-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-08-031-0/+21
PR 1649/cpukit * libcsupport/Makefile.am, libcsupport/src/getgid.c: Make sure all get and set gid and egid routines are present and in their own files. * libcsupport/src/setegid.c, libcsupport/src/setgid.c: New files.
