path: root/cpukit/libcsupport/src/seteuid.c (follow)
* libcsupport: Doxygen enhancement task #9Alex Ivanov2012-12-131-0/+7
* Remove redundant includes.Ralf Corsepius2010-08-031-3/+1
* 2010-07-30 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-08-021-0/+26
PR 1645/cpukit * libcsupport/src/getuid.c: Moved setuid() routine to its own file. * libcsupport/src/setuid.c: New file with setuid() routine. * libcsupport/src/seteuid.c: New file with seteuid() routine.
