#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7975223
http://www.google-melange.com/gci/task/view/google/gci2012/7992210
PR 1649/cpukit
* libcsupport/Makefile.am, libcsupport/src/getgid.c: Make sure all get
and set gid and egid routines are present and in their own files.
* libcsupport/src/setegid.c, libcsupport/src/setgid.c: New files.
