* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | 2010-08-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-02 | 1 | -71/+71 |
| | | | | * libcsupport/src/base_fs.c, libcsupport/src/rtems_mkdir.c: Formatting. | ||||
* | 2010-06-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-06-08 | 1 | -0/+141 |
PR 1524/filesystem * libcsupport/src/rtems_mkdir.c: New file. * libcsupport/src/Makefile.am: Reflect change above. * libcsupport/include/rtems/libio.h: Added rtems_mkdir(). * libmisc/fsmount/fsmount.h, libmisc/fsmount/fsmount.c, libblock/src/bdpart-mount.c, libnetworking/rtems/mkrootfs.h, libnetworking/rtems/mkrootfs.c, libfs/src/pipe/pipe.c: Use rtems_mkdir(). Removed rtems_fsmount_create_mount_point() and rtems_rootfs_mkdir(). |
