In POSIX, zero size memory allocations are implementation-defined
behaviour. The implementation has two options:
https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
Linux and FreeBSD return a unique pointer for zero size memory
allocations. Return NULL on RTEMS to more likely catch the use of a
zero size memory area by erroneous applications.
Update #4390.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Replace malloc_is_system_state_OK() with _Malloc_System_state() to allow
early allocations, e.g. in bsp_start(). Here the _Thread_Executing is
NULL, thus an _API_Mutex_Lock() would lead to a NULL pointer access.
Move malloc() support code to general case
rtems_heap_allocate_aligned_with_boundary(). Use
rtems_heap_allocate_aligned_with_boundary() to avoid duplicated code.
Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
Move system state check to malloc_is_system_state_OK().
* libcsupport/src/rtems_memalign.c, score/include/rtems/score/heap.h:
Remove stray references to malloc boundary.
PR 1472/cpukit
* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h,
libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/realloc.c,
libcsupport/src/rtems_memalign.c: Remove malloc boundary code. It has
not been used since before 4.6 and is bitrotted.
* libcsupport/src/malloc_boundary.c: Removed.
* libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_sbrk_helpers.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/mallocfreespace.c,
libcsupport/src/mallocinfo.c, libcsupport/src/realloc.c,
libcsupport/src/rtems_memalign.c, sapi/include/confdefs.h,
score/inline/rtems/score/thread.inl: Add support for optionally
having a unified work area. In other words, the RTEMS Workspace and C
Program Heap are the same pool of memory.
libcsupport/src/malloc_walk.c, libcsupport/src/posix_memalign.c,
libcsupport/src/realloc.c, score/src/heapwalk.c: Add rtems_memalign
as helper and as exposed nmemalign variant with few restrictions.
Also turn on compilation of _Heap_Walk but make forced calls to it
conditionally compiled. This should allow more flexibility to the
user as to run-time checking of the heap.
* libcsupport/src/rtems_memalign.c: New file.
