2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2013-06-25 | heap: Add _Heap_Greedy_allocate_all_except_largest | Sebastian Huber | 1 | -0/+16 | |
Add rtems_workspace_greedy_allocate_all_except_largest() and rtems_heap_greedy_allocate_all_except_largest(). | |||||
2012-12-10 | libcsupport: Doxygen enhancement task #5 | Alex Ivanov | 1 | -0/+7 | |
http://www.google-melange.com/gci/task/view/google/gci2012/7992211 | |||||
2012-07-17 | score: Change greedy allocation API | Sebastian Huber | 1 | -2/+5 | |
2012-02-10 | Added support functions for greedy heap allocation | Sebastian Huber | 1 | -0/+37 | |
Various tests must check program paths that result due to failed memory allocations from the heap. To avoid tinkering with internal heap structures throughout the test code these functions should be used. |
