#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
http://www.google-melange.com/gci/task/view/google/gci2012/8009205
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
