path: root/cpukit/libcsupport/src/rtems_heap_extend.c (follow)
* Canonicalize config.h includeSebastian Huber2020-04-161-2/+2
* 2011-02-17 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-02-171-0/+45
* libcsupport/src/rtems_heap_extend.c: New file. * libcsupport/Makefile.am: Reflect change from above. * libcsupport/include/rtems/malloc.h: Declare rtems_heap_extend(). * score/include/rtems/score/heap.h: Documentation.
