2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-02-17 | 2011-02-17 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 1 | -0/+45 | |
* libcsupport/src/rtems_heap_extend.c: New file. * libcsupport/Makefile.am: Reflect change from above. * libcsupport/include/rtems/malloc.h: Declare rtems_heap_extend(). * score/include/rtems/score/heap.h: Documentation. |
