path: root/cpukit/libcsupport/src/rmdir.c (follow)
* Moved the rmnod callback from the operations table to the handler table.Jennifer Averett1999-10-291-2/+2
* Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1999-10-121-8/+4
| | | | | places to make sure memory allocated for filesystem specifif nodes gets freed.
* Added call to freenod to let each filesystem free its own internalJoel Sherrill1999-10-121-4/+18
| | | | node used to manage file access.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+56
