The zero size allocations had no consistent behaviour in RTEMS. For
example, malloc( 0 ) returned NULL and posix_memalign( &p, align, 0 )
returned in p a unique pointer (or NULL if no memory is available). In
POSIX, zero size memory allocations are implementation-defined
behaviour. The implementation has two options:
https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
Linux and FreeBSD return a unique pointer for zero size memory
allocations. Use this approach for RTEMS as well throughout the memory
allocation directives
Close #4390.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
application visible API.
The _Thread_Dispatch_is_enabled() is false if _ISR_Nest_level is not
equal to zero.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
http://www.google-melange.com/gci/task/view/google/gci2012/7992212
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
PR 1472/cpukit
* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h,
libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/realloc.c,
libcsupport/src/rtems_memalign.c: Remove malloc boundary code. It has
not been used since before 4.6 and is bitrotted.
* libcsupport/src/malloc_boundary.c: Removed.
* score/src/wkspace.c: Removed work space area consistency checks.
* libblock/include/rtems/ide_part_table.h: Functions are now
deprecated.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/calloc.c,
libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_report_statistics_plugin.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c,
rtems/inline/rtems/rtems/region.inl: Update for heap API changes.
2009-09-14 Christian Mauderer <christian.mauderer@embedded-brains.de>
* libcsupport/src/vprintk.c: Fixed warnings. Print nothing in case the
pointer to the string is NULL.
* libcsupport/src/realloc.c, rtems/include/rtems/rtems/region.h,
rtems/src/regioncreate.c, rtems/src/regionextend.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionmp.c, rtems/src/regionresizesegment.c,
sapi/include/rtems/config.h, score/include/rtems/score/heap.h,
score/include/rtems/score/protectedheap.h, score/src/heap.c,
score/src/heapallocate.c, score/src/heapallocatealigned.c,
score/src/heapextend.c, score/src/heapresizeblock.c,
score/src/heapsizeofuserarea.c, score/src/pheapallocate.c,
score/src/pheapallocatealigned.c, score/src/pheapextend.c,
score/src/pheapgetblocksize.c, score/src/pheapresizeblock.c: Change
sizes of heap/region and allocated objects in heap to intptr_t so
they can be larger than a single allocatable object (e.g. size_t).
* libcsupport/src/malloc_statistics_helpers.c,
rtems/include/rtems/rtems/support.h,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/workspace.c, sapi/include/confdefs.h,
score/include/rtems/score/wkspace.h, score/src/heap.c,
score/src/heapsizeofuserarea.c, score/src/pheapgetblocksize.c,
score/src/wkspace.c: Change size_t to ssize_t on all Heap, Workspace
and Region calls. On 16-bit architectures, size_t can be 16-bits
which would limit sizes to 64K.
* libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_sbrk_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/mallocfreespace.c,
libcsupport/src/mallocinfo.c, libcsupport/src/realloc.c,
libcsupport/src/rtems_memalign.c, sapi/include/confdefs.h,
score/inline/rtems/score/thread.inl: Add support for optionally
having a unified work area. In other words, the RTEMS Workspace and C
Program Heap are the same pool of memory.
libcsupport/src/malloc_walk.c, libcsupport/src/posix_memalign.c,
libcsupport/src/realloc.c, score/src/heapwalk.c: Add rtems_memalign
as helper and as exposed nmemalign variant with few restrictions.
Also turn on compilation of _Heap_Walk but make forced calls to it
conditionally compiled. This should allow more flexibility to the
user as to run-time checking of the heap.
* libcsupport/src/rtems_memalign.c: New file.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/src/malloc.c, libcsupport/src/mallocinfo.c,
libmisc/Makefile.am, libmisc/shell/main_mallocinfo.c,
libmisc/shell/shellconfig.h: Split malloc.c into multiple files with
one function per file. Also split out statistics into a separate file
which can be plugged in dynamically. Right now, it is always in. I
suspect that splitting the file removed more code than leaving
statistics in. I tinkered with malloc information command in the
shell. I resurrected the malloc arena code as malloc boundary. This
code is now compiled all the time even though it does not appear to
* libcsupport/include/rtems/malloc.h, libcsupport/src/_calloc_r.c,
libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c,
libcsupport/src/_realloc_r.c, libcsupport/src/calloc.c,
libcsupport/src/free.c, libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_get_statistics.c,
libcsupport/src/malloc_report_statistics.c,
libmisc/shell/main_perioduse.c: New files.
