path: root/cpukit/libcsupport/src/readdir.c (unfollow)
2001-01-082001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
1999-11-02Check for NULL being passed in.Joel Sherrill1-0/+3
1999-06-14Wrong prototype corrected.Joel Sherrill1-1/+1
1999-06-14Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>.Joel Sherrill1-0/+6
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-6/+69
1998-10-22Changed all of these to stubs.Joel Sherrill1-69/+5
1998-10-12New files.Joel Sherrill1-23/+40
1998-08-20Added CVS IdsJoel Sherrill1-0/+2
1998-08-19Base filesJoel Sherrill1-59/+21
1998-04-14New filesJoel Sherrill1-0/+97
