PR 1839/filesystem
* libcsupport/include/rtems/libio_.h, libcsupport/src/fchdir.c,
libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c,
libcsupport/src/fsync.c, libcsupport/src/ftruncate.c,
libcsupport/src/read.c, libcsupport/src/readv.c,
libcsupport/src/write.c, libcsupport/src/writev.c: Some calls did not
return proper status for permission errors or incorrectly permissions
at all.
* libcsupport/src/read.c, libcsupport/src/write.c: Remove redundant
check for 0 size request.
* libcsupport/include/rtems/libio.h: Removed file_info and handlers
fields in rtems_libio_t.
* libcsupport/src/close.c, libcsupport/src/fcntl.c,
libcsupport/src/fdatasync.c, libcsupport/src/fstat.c,
libcsupport/src/getdents.c, libcsupport/src/ioctl.c,
libcsupport/src/libio_sockets.c, libcsupport/src/lseek.c,
libcsupport/src/open.c, libcsupport/src/read.c,
libcsupport/src/readv.c, libcsupport/src/write.c,
libcsupport/src/writev.c, libfs/src/devfs/devclose.c,
libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c,
libfs/src/devfs/devread.c, libfs/src/devfs/devwrite.c
libfs/src/dosfs/msdos_dir.c libfs/src/dosfs/msdos_file.c
libfs/src/imfs/deviceio.c libfs/src/imfs/imfs_directory.c
libfs/src/imfs/imfs_fifo.c libfs/src/imfs/memfile.c
libfs/src/nfsclient/src/nfs.c libfs/src/rfs/rtems-rfs-rtems-file.c
libfs/src/rfs/rtems-rfs-rtems.h libnetworking/lib/ftpfs.c: Reflect
changes above.
* libcsupport/src/chdir.c, libcsupport/src/chmod.c,
libcsupport/src/chown.c, libcsupport/src/close.c,
libcsupport/src/eval.c, libcsupport/src/fchdir.c,
libcsupport/src/fchmod.c, libcsupport/src/fchown.c,
libcsupport/src/fcntl.c, libcsupport/src/fdatasync.c,
libcsupport/src/freenode.c, libcsupport/src/fstat.c,
libcsupport/src/ioctl.c, libcsupport/src/link.c,
libcsupport/src/lseek.c, libcsupport/src/mknod.c,
libcsupport/src/mount.c, libcsupport/src/open.c,
libcsupport/src/read.c, libcsupport/src/readlink.c,
libcsupport/src/readv.c, libcsupport/src/rmdir.c,
libcsupport/src/stat.c, libcsupport/src/statvfs.c,
libcsupport/src/symlink.c, libcsupport/src/unlink.c,
libcsupport/src/unmount.c, libcsupport/src/write.c: Removed
filesystem checks for NULL methods checks from the main posix
rountines. These are now required to have at a miminum default
routines in the tables.
* libcsupport/src/read.c, libcsupport/src/write.c: read(2) and write(2)
should return 0 when passed a count of 0 after verifying other
possible errors.
* libcsupport/src/read.c, libcsupport/src/write.c: Fix spacing.
* include/chain.h, include/clockdrv.h, include/console.h,
include/iosupp.h, include/rtc.h, include/spurious.h,
include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h,
include/rtems/libio_.h, include/rtems/termiostypes.h,
include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h,
include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c,
src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c,
src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c,
src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c,
src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c,
src/fcntl.c, src/fdatasync.c, src/fpathconf.c,
src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c,
src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c,
src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c,
src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c,
src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c,
src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c,
src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c,
src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c,
src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c,
src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c,
src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c,
src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c,
src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for
license changed.
* include/rtems/libio_.h: Remove set_errno_and_return_minus_one.
* libc/cfsetispeed.c: Include <rtems/seterr.h>.
Apply rtems_set_errno_and_return_minus_one.
* libc/cfsetospeed.c: Include <rtems/seterr.h>.
* libc/chdir.c: Include <rtems/seterr.h>.
* libc/chmod.c: Include <rtems/seterr.h>.
* libc/chown.c: Include <rtems/seterr.h>.
* libc/chroot.c: Include <rtems/seterr.h>.
* libc/closedir.c: Include <rtems/seterr.h>.
* libc/eval.c: Include <rtems/seterr.h>.
* libc/fchdir.c: Include <rtems/seterr.h>.
* libc/fchmod.c: Include <rtems/seterr.h>.
* libc/fdatasync.c: Include <rtems/seterr.h>.
* libc/fpathconf.c: Include <rtems/seterr.h>.
* libc/fstat.c: Include <rtems/seterr.h>.
* libc/fsync.c: Include <rtems/seterr.h>.
* libc/ftruncate.c: Include <rtems/seterr.h>.
* libc/getdents.c: Include <rtems/seterr.h>.
* libc/ioctl.c: Include <rtems/seterr.h>.
* libc/link.c: Include <rtems/seterr.h>.
* libc/lseek.c: Include <rtems/seterr.h>.
* libc/mknod.c: Include <rtems/seterr.h>.
* libc/open.c: Include <rtems/seterr.h>.
* libc/read.c: Include <rtems/seterr.h>.
* libc/readlink.c: Include <rtems/seterr.h>.
* libc/rmdir.c: Include <rtems/seterr.h>.
* libc/stat.c: Include <rtems/seterr.h>.
* libc/symlink.c: Include <rtems/seterr.h>.
* libc/tcsetattr.c: Include <rtems/seterr.h>.
* libc/telldir.c: Include <rtems/seterr.h>.
* libc/ttyname.c: Include <rtems/seterr.h>.
* libc/ttyname_r.c: Include <rtems/seterr.h>.
* libc/unlink.c: Include <rtems/seterr.h>.
* libc/unmount.c: Include <rtems/seterr.h>.
* libc/utime.c: Include <rtems/seterr.h>.
* libc/write.c: Include <rtems/seterr.h>.
libc/utime.c, libc/write.c:
<rtems/XXX.h>.
<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
all conflicts.
PROBLEMS
can/will be fixed.
