path: root/cpukit/libcsupport/src/privateenv.c (follow)
* Canonicalize config.h includeSebastian Huber2020-04-161-2/+2
* libio: Add POSIX user environment pointer to TCBSebastian Huber2020-02-251-22/+45
| | | | | | | | | | The IO library used a POSIX key to store an optional POSIX user environment pointer. This pulled in the POSIX keys support in every application configuration. Add a user environment pointer to the thread control block (TCB) instead. Applications which do not need the POSIX user environment will just get an overhead of one pointer per thread. Close #3882.
* libio: Fix deadlock in location managementSebastian Huber2017-03-161-2/+2
| | | | | | | | Perform a context-dependent deferred location release to avoid a deadlock on the file system instance locks, for example during a chdir(). Update #2936.
* score: Add Thread_Change_life()Sebastian Huber2016-05-201-4/+6
| | | | | | | | | Add _Thread_Change_life_locked() as a general function to alter the thread life state. Use it to implement _Thread_Set_life_protection() as a first step. Update #2555. Update #2626.
* Filesystem: Thread life protection for env changesSebastian Huber2015-05-191-10/+10
* privateenv.c: Remove unused variable warningJoel Sherrill2014-04-041-1/+0
* privateenv: Use POSIX keys instead of task variables.Christian Mauderer2014-03-271-18/+19
* privateenv: Remove sharing of user environment between threads.Christian Mauderer2014-03-271-56/+4
* Include missing <rtems/score/threaddispatch.h>Sebastian Huber2013-07-261-3/+1
* libcsupport: Doxygen enhancement task #9Alex Ivanov2012-12-131-4/+7
* Filesystem: Reference counting for locationsSebastian Huber2012-03-131-162/+125
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01.
* 2010-09-08 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-09-081-40/+47
| | | | | | PR 1698/cpukit * libcsupport/src/privateenv.c: Check return values of rtems_filesystem_evaluate_path().
* 2010-08-29 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-08-291-38/+48
| | | | | | * libcsupport/src/privateenv.c: Add macro to test status when RTEMS_DEBUG is enabled. Note than evaluation of root directory should always work.
* 2010-07-29 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-291-29/+54
| | | | | | PR 1620/cpukit * libcsupport/src/privateenv.c: Significant clean up and rework to improve testability.
* 2010-07-26 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-261-2/+1
| | | | | | | | | | * libcsupport/src/privateenv.c, libmisc/cpuuse/cpuusagereport.c, posix/Makefile.am, posix/include/rtems/posix/key.h, posix/src/keycreate.c, posix/src/keydelete.c, score/src/iterateoverthreads.c: Since removing ITRON, the loop over all APIs for tasks has a path that cannot be reached. Either modify the code or mark tests for NULL as RTEMS_DEBUG. * posix/src/keyfreememory.c: New file.
* 2010-07-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-151-28/+35
| | | | * libcsupport/src/privateenv.c: Fix bug.
* 2010-05-31 Chris Johns <chrisj@rtems.org>Chris Johns2010-05-311-11/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/Makefile.am: Add mount-mgr.c. * libcsupport/src/mount-mgr.c: New. * include/rtems/fs.h: Added rtems_filesystem_location_mount. * libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New mount interface. It is similar to Linux. * libcsupport/include/rtems/libio_.h: Remove the init_fs_mount_table call. * libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use the new mount call. Remove setting the root node in the global pathloc. Mount does this now. * libcsupport/src/privateenv.c: Remove the hack to set the root mount table entry in the environment. * libcsupport/src/unmount.cL Free the target string. * libblock/src/bdpart-mount.c: New mount API. * libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c, libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c, libfs/src/imfs/miniimfs_init.c, libfs/src/nfsclient/src/librtemsNfs.h, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h, libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h, libnetworking/rtems/tftp.h: New mount_h API. * libfs/src/devfs/devfs_eval.c: Local include of extern ops. * libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount me call and fixed the initialisation to happen when mounting. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount filesystem files. * libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to the new mount table values. * libmisc/shell/main_mount_ftp.c, libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c, libmisc/shell/main_mount_tftp.c: Removed. * libmisc/shell/main_mount.c: Use the new mount API. Also access the file system table for the file system types. * libnetworking/lib/tftpDriver.c: Updated to the new mount API. Fixed to allow mounting from any mount point. Also can now have more than file system mounted. * sapi/include/confdefs.h: Add file system configuration support.
* 2009-06-12 Chris Johns <chrisj@rtems.org>Chris Johns2009-06-121-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c: Update comments. * libblock/src/bdpart.c, libblock/src/ide_part_table.c: Get the device from the rdev field of the stat buf. * libcsupport/include/rtems/libio.h: Add a path length to evalpath handler. Add parent locations to rmmod and unlink handlers. * libcsupport/include/rtems/libio_.h: Add a path length to rtems_filesystem_evaluate_path. Add rtems_filesystem_evaluate_relative_path, rtems_filesystem_dirname, and rtems_filesystem_prefix_separators. Remove rtems_filesystem_evaluate_parent. * libcsupport/src/base_fs.c, libcsupport/src/chdir.c, libcsupport/src/chmod.c, libcsupport/src/chown.c, libcsupport/src/chroot.c, libcsupport/src/fchdir.c, libcsupport/src/link.c, libcsupport/src/mount.c, libcsupport/src/open.c, libcsupport/src/privateenv.c, libcsupport/src/readlink.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devstat.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/ioman.c, libfs/src/pipe/pipe.c, libmisc/fsmount/fsmount.c, libnetworking/lib/ftpfs.c: Add the length parameter to the eval call. * libcsupport/src/eval.c: Add rtems_filesystem_prefix_separators, rtems_filesystem_dirname, rtems_filesystem_evaluate_relative_path. Add the length parameter to the eval call. * libcsupport/src/rmdir.c: Find the parent pathloc then the node pathloc from that node. Remove the call to find the parent given the node pathloc. * libcsupport/src/stat.c: Add the length parameter to the eval call. Set the device into the rdev field. * libcsupport/src/unlink.c: Find the parent pathloc then the node pathloc from that node. Remove the call to find the parent given the node pathloc. * libfs/src/dosfs/fat.c, libfs/src/dosfs/msdos_format.c: Get the disk device number from the stat rdev field. * libfs/src/dosfs/msdos.h: Add the length parameter to the eval call. Add the parent pathloc to the rmnod handler. * libfs/src/dosfs/msdos_dir.c: Add the parent pathloc to the rmnod handler. * libfs/src/dosfs/msdos_eval.c: Add the length parameter to the eval and token call. * libfs/src/imfs/imfs_directory.c: Add the parent pathloc to the rmnod handler. * libfs/src/imfs/imfs_fchmod.c: Do not test the mode flags for only the allowed flags. Add the missing flags spec'ed in the POSIX standard. * libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_rmnod.c, libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/memfile.c: Add the parent node. Currently ignored in the IMFS. * libfs/src/imfs/imfs_stat.c: Return the device number in the rdev field. * libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_symlink.c : Add the length parameter to the token call. * libfs/src/nfsclient/src/nfs.c: Add the length parameter to the eval call and parent node to the rmnod and unlink command. * libmisc/shell/internal.h: Remove the libc mounter decl to make public. * libmisc/shell/main_mount.c: Add support for hooking external mount support for new file systems. * libmisc/shell/shell.h: Add helper functions for the mount command.
* 2008-07-03 Chris Johns <chrisj@rtems.org>Chris Johns2008-07-031-1/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * cpukit/libcsupport/include/chain.h: Removed. Use the SAPI interface that is supported. * cpukit/libcsupport/Makefile.am, cpukit/libcsupport/preinstall.am: Remove chain.h header references. * cpukit/sapi/include/rtems/chain.h, cpukit/sapi/inline/rtems/chain.inl: New. A supported chains interface. * cpukit/sapi/Makefile.am, cpukit/sapi/preinstall.am: Updated to include the new chains interface. * cpukit/libfs/src/imfs/imfs.h, cpukit/libfs/src/imfs/imfs_creat.c, cpukit/libfs/src/imfs/imfs_debug.c, cpukit/libfs/src/imfs/imfs_directory.c, cpukit/libfs/src/imfs/imfs_fsunmount.c, cpukit/libfs/src/imfs/imfs_getchild.c, cpukit/libfs/src/imfs/imfs_load_tar.c, cpukit/libfs/src/imfs/imfs_rmnod.c, cpukit/libfs/src/imfs/memfile.c, cpukit/libfs/src/nfsclient/src/nfs.c, cpukit/libcsupport/include/rtems/libio.h, cpukit/libcsupport/src/malloc_deferred.c, cpukit/libcsupport/src/mount.c, cpukit/libcsupport/src/privateenv.c, cpukit/libcsupport/src/unmount.c: Change to the new chains interface. * cpukit/libcsupport/src/malloc_boundary.c: Remove warning.
* Remove stray white spaces.Ralf Corsepius2004-04-181-6/+6
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/chain.h, include/clockdrv.h, include/console.h, include/iosupp.h, include/rtc.h, include/spurious.h, include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h, include/rtems/termiostypes.h, include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h, include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c, src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c, src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c, src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c, src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c, src/fcntl.c, src/fdatasync.c, src/fpathconf.c, src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c, src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c, src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c, src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c, src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c, src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c, src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c, src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c, src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c, src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c, src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c, src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c, src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for license changed.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-02-281-1/+3
* Patch against RTEMS-ss-20030128Joel Sherrill2003-02-201-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Author: Till Straumann <strauman@slac.stanford.edu> 2003/2/11 This patch addresses the following issues: 2003-02-20 Till Straumann <strauman@slac.stanford.edu> PR 349/bsps * src/mount.c, src/privateenv.c: - mount() bugfix: allocated 'loc' node must be released if mount fails due to missing node_type_h - silence compiler warning about improper pointer type Index: cpukit/libcsupport/src/mount.c =================================================================== RCS file: /afs/slac/g/spear/cvsrep/rtems/src-20030128/cpukit/libcsupport/src/mount.c,v retrieving revision 1.1.1.2 diff -c -r1.1.1.2 mount.c *** cpukit/libcsupport/src/mount.c 29 Jan 2003 22:57:19 -0000 1.1.1.2 --- cpukit/libcsupport/src/mount.c 7 Feb 2003 20:47:49 -0000 *************** *** 142,147 **** --- 142,149 ---- mount_point, RTEMS_LIBIO_PERMS_RWX, &loc, TRUE ) == -1 ) goto cleanup_and_bail; + loc_to_free = &loc; + /* * Test for node_type_h */ *************** *** 155,161 **** * Test to see if it is a directory */ - loc_to_free = &loc; if ( loc.ops->node_type_h( &loc ) != RTEMS_FILESYSTEM_DIRECTORY ) { errno = ENOTDIR; goto cleanup_and_bail; --- 157,162 ---- Index: cpukit/libcsupport/src/privateenv.c =================================================================== RCS file: /afs/slac/g/spear/cvsrep/rtems/src-20030128/cpukit/libcsupport/src/privateenv.c,v retrieving revision 1.1.1.3 diff -c -r1.1.1.3 privateenv.c *** cpukit/libcsupport/src/privateenv.c 29 Jan 2003 22:57:20 -0000 1.1.1.3 --- cpukit/libcsupport/src/privateenv.c 30 Jan 2003 18:01:40 -0000 *************** *** 65,71 **** tmp->refcnt = 1; #endif ! sc = rtems_task_variable_add(RTEMS_SELF,(void*)&rtems_current_user_env,free_user_env); if (sc != RTEMS_SUCCESSFUL) { /* don't use free_user_env because the pathlocs are * not initialized yet --- 65,71 ---- tmp->refcnt = 1; #endif ! sc = rtems_task_variable_add(RTEMS_SELF,(void*)&rtems_current_user_env,(void(*)(void *))free_user_env); if (sc != RTEMS_SUCCESSFUL) { /* don't use free_user_env because the pathlocs are * not initialized yet
* 2003-01-03 Till Straumann <strauman@slac.stanford.edu>Jennifer Averett2003-01-031-13/+93
| | | | | * ChangeLog, base_fs.c, getpwent.c, privateenv.c Per PR303, Fix violation of node_access copy syemantics
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-0/+2
| | | | | | * libc/Makefile.am: Add MULTISUBDIR support. * libc/fcntl.c: Add #include <stdarg.h>. * libc/privateenv.c: Add #include <stdlib.h>.
* 2001-04-20 Correo Fernando-ruiz <correo@fernando-ruiz.com>Joel Sherrill2001-04-201-7/+49
| | | | | | | | | | | | | | | | | * include/rtems/libio_.h, libc/chroot.c, libc/privateenv.c: Private environment and chroot() enhancements and fixes. Comments: + privateenv has been modified to let at chroot() to be more POSIX like Sergei Organov recommended. + A task owner lets that rtems_set_private_env() will be called twice or more times. + chroot() can be called without a previous rtems_set_private_env(); (transpanrently) + The second call of rtems_set_private_env() makes a internal chroot("/") into global imfs_root. + chroot() runs like chdir() without a previous chdir("/") with the global root. + The current directory can be in a wrong place like Linux and many other Unices.
* 2001-01-25 Fernando Ruiz <fernando.ruiz@ctv.es>Joel Sherrill2001-01-251-0/+37
* Alternate email is correo@fernando-ruiz.com * libc/privateenv.c: New file. * include/rtems/libio_.h, libc/Makefile.am, libc/base_fs.c, libc/unmount.c: Moved default umask, current working directory, root, and links followed count into a structure "user environment" that can then be treated as a unit. This enable giving unique copies of these to individual threads or collection of threads.
