The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
of this patch set.
http://www.google-melange.com/gci/task/view/google/gci2012/8009205
* libcsupport/Makefile.am, libcsupport/src/printk.c:
* libcsupport/src/printk_plugin.c: New file.
include/rtems/bspIo.h, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuuse.h, libmisc/stackchk/check.c,
libmisc/stackchk/stackchk.h: rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemonreportstatistics.c: Added capability to specify
your own "printf" routine to various reporting functions. This
added an XXX_with_plugin as the underlying implementation for
+ rtems_rate_monotonic_report_statistics
+ rtems_stack_checker_report_usage
+ rtems_cpu_usage_report
As demonstration, the http netdemo can now print out stack
and cpu usage reports.
