* | printertask.c: Fix Unchecked return value (CID #1399710) | Ryan Long | 2021-02-26 | 1 | -3/+8 |
| | | | | | | | CID 1399710: Unchecked return value in printer_task(). CID 1472764: Unchecked return value in rtems_print_printer_task(). Closes #4258 | ||||
* | score: Add debug support to chains | Sebastian Huber | 2016-07-22 | 1 | -0/+1 |
| | | | | | | | This helps to detect * double insert, append, prepend errors, and * get from empty chain errors. | ||||
* | Add printer task | Sebastian Huber | 2016-06-22 | 1 | -0/+203 |
