#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
We must use vfprintf().
of this patch set.
