* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | posix_devctl - Add support for SOCKCLOSE | Joel Sherrill | 2020-01-17 | 1 | -1/+15 |
| | | | | | | | | | The FACE Technical Standard, Edition 3.0 and later require the definition of the subcommand SOCKCLOSE in <devctl.h>. Reference: ​https://www.opengroup.org/face closes #3856. | ||||
* | posix_devctl: Fix for pre C99 | Sebastian Huber | 2017-03-02 | 1 | -5/+5 |
| | | | | | Use __restrict just like in <devctl.h> to avoid compiler errors with older GCC, e.g. 4.8 or 4.9. | ||||
* | Add support for posix_devctl() | Joel Sherrill | 2017-01-11 | 1 | -0/+72 |
