#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #2825.
Update #2825.
Rename open_dev_console() to rtems_libio_post_driver(). Rename
rtems_libio_supp_helper to rtems_libio_post_driver_helper.
* libcsupport/src/open_dev_console.c: Use constant numbers to avoid
overflow when shifting on 16-bit targets.
* libcsupport/Makefile.am:
* libcsupport/src/open_dev_console.c: New file.
PR 1232/bsps
* bsppost.c: It should not be a fatal error to not have a console.
PROBLEMS
can/will be fixed.
component.
