path: root/cpukit/libcsupport/src/mallocdirtydefault.c (follow)
* config: Add <rtems/confdefs/malloc.h>Sebastian Huber2020-02-251-0/+34
Remove all comments and copyrightable content from the moved content. Use BSD-2-Clause license for new file. Move the default configuration to library files so that application configurations do not include the definitions for the default case. Update #3053. Update #3875.
