* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h,
libcsupport/src/malloc_walk.c, libcsupport/src/posix_memalign.c,
libcsupport/src/realloc.c, score/src/heapwalk.c: Add rtems_memalign
as helper and as exposed nmemalign variant with few restrictions.
Also turn on compilation of _Heap_Walk but make forced calls to it
conditionally compiled. This should allow more flexibility to the
user as to run-time checking of the heap.
* libcsupport/src/rtems_memalign.c: New file.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/src/malloc.c, libcsupport/src/mallocinfo.c,
libmisc/Makefile.am, libmisc/shell/main_mallocinfo.c,
libmisc/shell/shellconfig.h: Split malloc.c into multiple files with
one function per file. Also split out statistics into a separate file
which can be plugged in dynamically. Right now, it is always in. I
suspect that splitting the file removed more code than leaving
statistics in. I tinkered with malloc information command in the
shell. I resurrected the malloc arena code as malloc boundary. This
code is now compiled all the time even though it does not appear to
* libcsupport/include/rtems/malloc.h, libcsupport/src/_calloc_r.c,
libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c,
libcsupport/src/_realloc_r.c, libcsupport/src/calloc.c,
libcsupport/src/free.c, libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_get_statistics.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_report_statistics.c,
libcsupport/src/malloc_report_statistics_plugin.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c,
libmisc/shell/main_perioduse.c: New files.
