* libcsupport/src/malloc_report_statistics_plugin.c: Fixed format
specifiers.
* score/src/wkspace.c: Removed work space area consistency checks.
* libblock/include/rtems/ide_part_table.h: Functions are now
deprecated.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/calloc.c,
libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_initialize.c,
libcsupport/src/malloc_report_statistics_plugin.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c,
rtems/inline/rtems/rtems/region.inl: Update for heap API changes.
2009-09-14 Christian Mauderer <christian.mauderer@embedded-brains.de>
* libcsupport/src/vprintk.c: Fixed warnings. Print nothing in case the
pointer to the string is NULL.
* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h,
libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_p.h,
libmisc/shell/shell.c, libmisc/shell/shell.h,
score/src/objectinitializeinformation.c: Add posix_memalign. Split
out management of deferred frees to subroutines.
* libcsupport/src/malloc_deferred.c, libcsupport/src/posix_memalign.c: New files.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/src/malloc.c, libcsupport/src/mallocinfo.c,
libmisc/Makefile.am, libmisc/shell/main_mallocinfo.c,
libmisc/shell/shellconfig.h: Split malloc.c into multiple files with
one function per file. Also split out statistics into a separate file
which can be plugged in dynamically. Right now, it is always in. I
suspect that splitting the file removed more code than leaving
statistics in. I tinkered with malloc information command in the
shell. I resurrected the malloc arena code as malloc boundary. This
code is now compiled all the time even though it does not appear to
* libcsupport/include/rtems/malloc.h, libcsupport/src/_calloc_r.c,
libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c,
libcsupport/src/_realloc_r.c, libcsupport/src/calloc.c,
libcsupport/src/free.c, libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_get_statistics.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_report_statistics.c,
libmisc/shell/main_perioduse.c: New files.
