#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
Rename _Internal_error_Occurred() into _Terminate().
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Remove this function and statically initialize RTEMS_Malloc_GC_list.
PR 1924/cpukit
* sapi/include/rtems/config.h: New fields stack_space_size,
unified_work_area, and stack_allocator_avoids_work_space in
rtems_configuration_table.
* sapi/include/confdefs.h: Removed rtems_unified_work_area (this is
now part of the Configuration). Separate work space and stack space
estimate. Added CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
configuration option.
* libmisc/shell/main_wkspaceinfo.c, score/src/wkspace.c,
libcsupport/src/malloc_initialize.c: Update due to API changes.
* libcsupport/src/malloc_initialize.c: After discussion with Till
Straumann, revert the change from r1.12 to r1.13. This broke BSPs
with sbrk() support once the libbsp sbrk() framework was enhanced.
psim runs now.
* libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_initialize.c: Remove heap walks in case
RTEMS_DEBUG is defined.
* libcsupport/src/malloc_initialize.c: Clean up sbrk path now that a
test is available.
PR 1472/cpukit
* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h,
libcsupport/src/malloc_initialize.c, libcsupport/src/realloc.c,
libcsupport/src/rtems_memalign.c: Remove malloc boundary code. It has
not been used since before 4.6 and is bitrotted.
* libcsupport/src/malloc_boundary.c: Removed.
* score/src/wkspace.c: Removed work space area consistency checks.
* libblock/include/rtems/ide_part_table.h: Functions are now
deprecated.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/calloc.c,
libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_report_statistics_plugin.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c,
rtems/inline/rtems/rtems/region.inl: Update for heap API changes.
2009-09-14 Christian Mauderer <christian.mauderer@embedded-brains.de>
* libcsupport/src/vprintk.c: Fixed warnings. Print nothing in case the
pointer to the string is NULL.
* libcsupport/src/malloc_initialize.c, sapi/src/exinit.c,
score/src/threadstartmultitasking.c: Fix spacing.
* libmisc/stackchk/check.c: Move variable into compiler specific conditional.
* libcsupport/src/malloc_initialize.c: Add dummy
RTEMS_Malloc_Initialize.
* libcsupport/src/malloc_initialize.c: Fixed invalid function
parameter.
* libcsupport/src/malloc_initialize.c, score/Makefile.am,
score/include/rtems/score/protectedheap.h,
score/inline/rtems/score/heap.inl: Get total heap size correct when
using unified C Program Heap and RTEMS Workspace.
* score/src/pheapgetsize.c: New file.
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_sbrk_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/mallocfreespace.c,
libcsupport/src/mallocinfo.c, libcsupport/src/realloc.c,
libcsupport/src/rtems_memalign.c, sapi/include/confdefs.h,
score/inline/rtems/score/thread.inl: Add support for optionally
having a unified work area. In other words, the RTEMS Workspace and C
Program Heap are the same pool of memory.
libcsupport/src/malloc_deferred.c,
libcsupport/src/posix_memalign.c: Place all deferred free code and
place it in subroutines. Add plugin for dirtying allocated memory to
assist in debugging. Clean up comments and spacing as needed.
* libcsupport/src/malloc_dirtier.c: New file.
* libcsupport/Makefile.am: Add malloc_sbrk_helpers.c.
* libcsupport/include/rtems/malloc.h,
libcsupport/src/malloc.c, libcsupport/src/malloc_initialize.c,
libcsupport/src/malloc_statistics_helpers.c: Make sbrk()
support pluggable and optional. This eliminates the need for
heap extend and sbrk in the minimum footprint which is ~2.5K on
the SPARC.
* sapi/include/confdefs.h: Add the following configuration points:
+ CONFIGURE_MALLOC_STATISTICS
+ CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
* libcsupport/src/malloc_sbrk_helpers.c: New file.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/src/malloc.c, libcsupport/src/mallocinfo.c,
libmisc/Makefile.am, libmisc/shell/main_mallocinfo.c,
libmisc/shell/shellconfig.h: Split malloc.c into multiple files with
one function per file. Also split out statistics into a separate file
which can be plugged in dynamically. Right now, it is always in. I
suspect that splitting the file removed more code than leaving
statistics in. I tinkered with malloc information command in the
shell. I resurrected the malloc arena code as malloc boundary. This
code is now compiled all the time even though it does not appear to
* libcsupport/include/rtems/malloc.h, libcsupport/src/_calloc_r.c,
libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c,
libcsupport/src/_realloc_r.c, libcsupport/src/calloc.c,
libcsupport/src/free.c, libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_get_statistics.c,
libcsupport/src/malloc_report_statistics.c,
libmisc/shell/main_perioduse.c: New files.
