* | Include missing <string.h> | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
* | libcsupport: Doxygen Enhancement Task #8 | Alex Ivanov | 2012-12-15 | 1 | -2/+7 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7996208 | ||||
* | 2008-01-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-09 | 1 | -0/+30 |
* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h, libcsupport/src/free.c, libcsupport/src/malloc.c, libcsupport/src/malloc_deferred.c, libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h, libcsupport/src/malloc_sbrk_helpers.c, libcsupport/src/posix_memalign.c: Place all deferred free code and place it in subroutines. Add plugin for dirtying allocated memory to assist in debugging. Clean up comments and spacing as needed. * libcsupport/src/malloc_dirtier.c: New file. |
