The zero size allocations had no consistent behaviour in RTEMS. For
example, malloc( 0 ) returned NULL and posix_memalign( &p, align, 0 )
returned in p a unique pointer (or NULL if no memory is available). In
POSIX, zero size memory allocations are implementation-defined
behaviour. The implementation has two options:
https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
Linux and FreeBSD return a unique pointer for zero size memory
allocations. Use this approach for RTEMS as well throughout the memory
allocation directives
Close #4390.
Move rtems_calloc() since it only depends on rtems_malloc(). This may
make it easier to customize the heap allocator.
Change licence to BSD-2-Clause according to file history.
Update #3053.
Only include the deferred free support if free() is actually used by the
application.
The free() implementation in RTEMS supports that allocated memory is
freed in interrupt context. Since the heap is protected by a mutex, the
frees issued in interrupt context cannot immediately be freed to the
heap, instead they are placed on a deferred free list. This list is
emptied by the core allocation function
rtems_heap_allocate_aligned_with_boundary(). This adds a dependency to
free() in rtems_heap_allocate_aligned_with_boundary(). In order to
better support applications which only allocate memory and never free
it, this dependency should be avoided. Provide a weak default
implementation of _Malloc_Process_deferred_frees() for
rtems_heap_allocate_aligned_with_boundary(). In the free() module
provide the strong implementation.
Close #4032.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Close #3583.
This helps to detect
* double insert, append, prepend errors, and
* get from empty chain errors.
Call _Malloc_Process_deferred_frees() owning the allocator lock to
prevent deletion of the executing thread while doing the deferred frees.
Close #2617.
Replace malloc_is_system_state_OK() with _Malloc_System_state() to allow
early allocations, e.g. in bsp_start(). Here the _Thread_Executing is
NULL, thus an _API_Mutex_Lock() would lead to a NULL pointer access.
Move malloc() support code to general case
rtems_heap_allocate_aligned_with_boundary(). Use
rtems_heap_allocate_aligned_with_boundary() to avoid duplicated code.
Move system state check to malloc_is_system_state_OK().
The _Thread_Dispatch_is_enabled() is false if _ISR_Nest_level is not
equal to zero.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
http://www.google-melange.com/gci/task/view/google/gci2012/7975223
Remove this function and statically initialize RTEMS_Malloc_GC_list.
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
* cpukit/libcsupport/include/chain.h: Removed. Use the SAPI
interface that is supported.
* cpukit/libcsupport/Makefile.am,
cpukit/libcsupport/preinstall.am: Remove chain.h header
references.
* cpukit/sapi/include/rtems/chain.h,
cpukit/sapi/inline/rtems/chain.inl: New. A supported chains
interface.
* cpukit/sapi/Makefile.am, cpukit/sapi/preinstall.am: Updated to
include the new chains interface.
* cpukit/libfs/src/imfs/imfs.h,
cpukit/libfs/src/imfs/imfs_creat.c,
cpukit/libfs/src/imfs/imfs_debug.c,
cpukit/libfs/src/imfs/imfs_directory.c,
cpukit/libfs/src/imfs/imfs_fsunmount.c,
cpukit/libfs/src/imfs/imfs_getchild.c,
cpukit/libfs/src/imfs/imfs_load_tar.c,
cpukit/libfs/src/imfs/imfs_rmnod.c,
cpukit/libfs/src/imfs/memfile.c,
cpukit/libfs/src/nfsclient/src/nfs.c,
cpukit/libcsupport/include/rtems/libio.h,
cpukit/libcsupport/src/malloc_deferred.c,
cpukit/libcsupport/src/mount.c,
cpukit/libcsupport/src/privateenv.c,
cpukit/libcsupport/src/unmount.c: Change to the new chains
interface.
* cpukit/libcsupport/src/malloc_boundary.c: Remove warning.
* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h,
libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_sbrk_helpers.c,
libcsupport/src/posix_memalign.c: Place all deferred free code and
place it in subroutines. Add plugin for dirtying allocated memory to
assist in debugging. Clean up comments and spacing as needed.
* libcsupport/src/malloc_dirtier.c: New file.
libcsupport/src/malloc_report_statistics_plugin.c,
libmisc/shell/shell.c, libmisc/shell/shell.h,
score/src/objectinitializeinformation.c: Add posix_memalign. Split
out management of deferred frees to subroutines.
* libcsupport/src/malloc_deferred.c, libcsupport/src/posix_memalign.c: New files.
