path: root/cpukit/libcsupport/src/malloc.c (follow)
* Corrected Linux port for glibc2Joel Sherrill1998-01-301-1/+1
* Removed warning under linux port.Joel Sherrill1997-11-181-0/+5
* Added casts and fixed line break.Joel Sherrill1997-10-211-2/+3
* Merged newlib's libgloss support for rtems into this directory. ThisJoel Sherrill1997-01-291-18/+18
| | | | should simplify the build process.
* added malloc_walkJoel Sherrill1996-09-181-4/+35
| | | | miscellaneous corrections in casting.
* updates from Tony BennettJoel Sherrill1996-05-231-0/+3
* Updates from Tony Bennett.Joel Sherrill1996-04-221-1/+9
* bug fix in statistics from Tony Bennett (tbennett@divnc.com)Joel Sherrill1995-12-051-1/+3
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-31/+99
* Added functions to access the errno of the native system when using theJoel Sherrill1995-08-111-1/+8
| | | | | | | newlib C library. Fixed bug where length did not take into account amount added for alignment requirements.
* incorporate Tony's patches:Joel Sherrill1995-06-051-0/+1
| | | | | | | | | | + c/src/lib/libc/support/generic/malloc.c did not initialize the sbrk amount + _Thread_Handler in c/src/exec/rtems/thread.c left a window during the begin extension which could result in a context switch fixed places which did not correctly distinguish between an CPU_isr and a CPU_isr_entry.
* Initial revisionJoel Sherrill1995-05-111-0/+280
