http://www.google-melange.com/gci/task/view/google/gci2012/7992210
* libcsupport/Makefile.am: Split no_posix.c so using sleep() does not
pull in kill() stubs.
* libcsupport/src/kill_noposix.c, libcsupport/src/sleep_noposix.c:
New files.
* libcsupport/src/no_posix.c: Removed.
