http://www.google-melange.com/gci/task/view/google/gci2012/7975223
PR 1645/cpukit
* libcsupport/src/getuid.c: Moved setuid() routine to its own
file.
* libcsupport/src/setuid.c: New file with setuid() routine.
* libcsupport/src/seteuid.c: New file with seteuid() routine.
PR 449/rtems:
* src/getegid.c: New (Copied from ../posix/src).
* src/geteuid.c: New (Copied from ../posix/src).
* src/getgid.c: New (Copied from ../posix/src).
* src/getgroups.c: New (Copied from ../posix/src).
* src/getlogin.c: New (Copied from ../posix/src).
* src/getpgrp.c: New (Copied from ../posix/src).
* src/getpid.c: New (Copied from ../posix/src).
* src/getppid.c: New (Copied from ../posix/src).
* src/getuid.c: New (Copied from ../posix/src).
* src/setpgid.c: New (Copied from ../posix/src).
* src/setsid.c: New (Copied from ../posix/src).
* src/no_posix: Remove getpid and _getpid_r.
