#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Declaration provided by Newlib since 2014.
Update #3409.
* configure.ac: Check for getrusage.h decl.
* libcsupport/src/getrusage.c:
Apply HAVE_DECL_GETRUSAGE (Missing prototypes).
* libcsupport/src/getrusage.c: Formatting.
* libcsupport/Makefile.am: Add getrusage().
* libcsupport/src/getrusage.c: New file.
