* | 2007-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-29 | 1 | -1/+1 |
| | | | | * libcsupport/src/getpwent.c: Remove bogus cast to long. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-18 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/chain.h, include/clockdrv.h, include/console.h, include/iosupp.h, include/rtc.h, include/spurious.h, include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h, include/rtems/termiostypes.h, include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h, include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c, src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c, src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c, src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c, src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c, src/fcntl.c, src/fdatasync.c, src/fpathconf.c, src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c, src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c, src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c, src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c, src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c, src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c, src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c, src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c, src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c, src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c, src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c, src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c, src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for license changed. | ||||
* | 2003-01-03 Till Straumann <strauman@slac.stanford.edu> | Jennifer Averett | 2003-01-03 | 1 | -18/+0 |
| | | | | | * ChangeLog, base_fs.c, getpwent.c, privateenv.c Per PR303, Fix violation of node_access copy syemantics | ||||
* | 2002-10-02 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 2002-10-02 | 1 | -113/+326 |
| | | | | | | | * src/getpwent.c: Per PR283, reimplement to address reentrancy problems. * src/getgrent.c: Removed as functionality is now just a wrapper for common routines in src/getpwent.c. * Makefile.am: Reflect file removal. | ||||
* | 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com> | Joel Sherrill | 2001-08-09 | 1 | -2/+17 |
| | | | | | * libc/getgrent.c, libc/getpwent.c: the 'ls' and more related command previous failed after a chroot(). (unknown user & group) | ||||
* | 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es> | Joel Sherrill | 2001-05-24 | 1 | -5/+7 |
| | | | | | | | * libc/ttyname.c (ttyname_r): Removed duplicate call to closedir(). * libc/getpwent.c: Create a more robust /etc/passwd and /etc/group. * libc/base_fs.c: Change permissions of files and directories. Now uses octal constants. | ||||
* | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-08 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | ||||
* | Added code to initialize the /etc/group and /etc/passwd files. | Joel Sherrill | 1999-07-02 | 1 | -0/+69 |
* | Fixed format strings and warnings. | Joel Sherrill | 1999-07-02 | 1 | -6/+6 |
* | Reentrant versions added by Joel. Signficant formatting cleanup. | Joel Sherrill | 1999-07-02 | 1 | -63/+92 |
* | Password and group routines added by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1999-07-02 | 1 | -0/+129 |
