http://www.google-melange.com/gci/task/view/google/gci2012/7992211
* libcsupport/src/getpagesize.c, posix/Makefile.am: Eliminate one copy
of getpagesize() and make it return an int.
* posix/src/getpagesize.c: Removed.
