2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -1/+1 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2014-11-20 | libcsupport: Use POSIX key for getgrent() | Sebastian Huber | 1 | -25/+0 | |
2014-11-20 | libcsupport: Split passwd/group support | Sebastian Huber | 1 | -0/+78 | |
2002-10-02 | 2002-10-02 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 1 | -193/+0 | |
* src/getpwent.c: Per PR283, reimplement to address reentrancy problems. * src/getgrent.c: Removed as functionality is now just a wrapper for common routines in src/getpwent.c. * Makefile.am: Reflect file removal. | |||||
2001-08-09 | 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com> | Joel Sherrill | 1 | -0/+17 | |
* libc/getgrent.c, libc/getpwent.c: the 'ls' and more related command previous failed after a chroot(). (unknown user & group) | |||||
2001-01-08 | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+3 | |
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | |||||
1999-07-02 | Added code to initialize the /etc/group and /etc/passwd files. | Joel Sherrill | 1 | -0/+22 | |
1999-07-02 | Fixed format strings and warnings. | Joel Sherrill | 1 | -3/+3 | |
1999-07-02 | Reentrant versions added by Joel. Signficant formatting cleanup. | Joel Sherrill | 1 | -52/+84 | |
1999-07-02 | Password and group routines added by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -0/+119 | |
