* | getgrent.c, record-client.c: Add missing includes for assert.h | Vijay Kumar Banerjee | 2021-02-27 | 1 | -0/+1 |
* | getgrent.c: Fix Unchecked return value error (CID #1459004) | Ryan Long | 2021-02-26 | 1 | -1/+3 |
| | | | | | | CID 1459004: Unchecked return value in endgrent(). Closes #4261 | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | libcsupport: Use POSIX key for getgrent() | Sebastian Huber | 2014-11-20 | 1 | -29/+59 |
* | libcsupport: Split passwd/group support | Sebastian Huber | 2014-11-20 | 1 | -0/+78 |
* | 2002-10-02 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 2002-10-02 | 1 | -193/+0 |
| | | | | | | | * src/getpwent.c: Per PR283, reimplement to address reentrancy problems. * src/getgrent.c: Removed as functionality is now just a wrapper for common routines in src/getpwent.c. * Makefile.am: Reflect file removal. | ||||
* | 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com> | Joel Sherrill | 2001-08-09 | 1 | -0/+17 |
| | | | | | * libc/getgrent.c, libc/getpwent.c: the 'ls' and more related command previous failed after a chroot(). (unknown user & group) | ||||
* | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-08 | 1 | -0/+3 |
| | | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | ||||
* | Added code to initialize the /etc/group and /etc/passwd files. | Joel Sherrill | 1999-07-02 | 1 | -0/+22 |
* | Fixed format strings and warnings. | Joel Sherrill | 1999-07-02 | 1 | -3/+3 |
* | Reentrant versions added by Joel. Signficant formatting cleanup. | Joel Sherrill | 1999-07-02 | 1 | -52/+84 |
* | Password and group routines added by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1999-07-02 | 1 | -0/+119 |
