path: root/cpukit/libcsupport/src/fstat.c (follow)
* Patch from Eric Norum <eric@skatter.usask.ca> to eliminate externalJoel Sherrill1999-03-011-28/+9
| | | | | IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine.
* More general fix based on bug report and patch from Ian Lance TaylorJoel Sherrill1999-01-201-0/+1
| | | | | | | | | | <ian@airs.com> to fix this problem: There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It does not check whether the file descriptor it is passed is open. This can cause it to make a null dereference if it is passed a file descriptor which is in the valid range but which was not opened, or which was already closed.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+94
