path: root/cpukit/libcsupport/src/fcntl.c (follow)
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+4
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-4/+6
| | | | | | | * libc/fcntl.c: Do not require every filesystem to have an fcntl() handler. Most fcntl() operations can be performed with no filesystem support. * ChangeLog: Corrected comment.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-2/+2
| | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
* 2000-08-11 Chris Johns <ccj@acm.org>Joel Sherrill2000-08-111-4/+10
| | | | | | | | | | | | | | | * libc/chmod.c: Return ENOTSUP if filesystem does not have handler. * libc/eval.c: Ditto. * libc/fcntl.c: Ditto. * libc/fsync.c: Ditto. * libc/ioctl.c: Ditto. * libc/ioman.c: Ditto. * libc/link.c: Ditto. * libc/memfile.c: Ditto. * libc/mknod.c: Ditto. * libc/symlink.c: Ditto. * libc/libio.h(rtems_filesystem_dev_major_t): New macro. * libc/libio.h(rtems_filesystem_dev_minor_t): New macro.
* Fixed F_SETFL to properly convert between internalJoel Sherrill1999-11-021-2/+3
| | | | libio flags and external fcntl.h style flags.
* Corrected return value.Jennifer Averett1999-03-311-1/+1
* Another cleanup patch for the previous rejected hunk.Joel Sherrill1999-03-191-0/+1
* A cleanup patch on fcntl.c from Eric Norum <eric@skatter.usask.ca> forJoel Sherrill1999-03-191-0/+2
| | | | | 2 lines of code that did not get included when Joel tried to manually add a rejected patch.
* Patch from Eric Norum <eric@skatter.usask.ca> that adds externalJoel Sherrill1999-03-191-24/+36
| | | | fcntl support and an external fcntl handler for sockets.
* Added support for F_GETFL and F_SETFL.Joel Sherrill1999-03-081-2/+3
* Added F_GETFL support so the fdopen() implementation in newlib 1.8.1Joel Sherrill1999-03-061-2/+17
| | | | | | | | would work. At the same time, the initial implementation of F_SETFL was added. A support routine was added to convert internal libio flags back to the POSIX style. Eventually the internal representation should be eliminated in the interest of simplicity and code reduction. This problem was reported by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
* Patch from Eric Norum <eric@skatter.usask.ca> to eliminate externalJoel Sherrill1999-03-011-7/+0
| | | | | IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine.
* More general fix based on bug report and patch from Ian Lance TaylorJoel Sherrill1999-01-201-0/+1
| | | | | | | | | | <ian@airs.com> to fix this problem: There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It does not check whether the file descriptor it is passed is open. This can cause it to make a null dereference if it is passed a file descriptor which is in the valid range but which was not opened, or which was already closed.
* Merged Eric Norum's select patch that was based on 4.0 and resolvedJoel Sherrill1998-12-101-4/+4
| | | | all conflicts.
* Added source for F_DUPFD.Jennifer Averett1998-12-031-12/+18
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+111
