path: root/cpukit/libcsupport/src/fchdir.c (follow)
* Canonicalize config.h includeSebastian Huber2020-04-161-2/+2
* libio: Add hold/drop iop referenceSebastian Huber2017-09-151-0/+1
| | | | | | | Check iop reference count in close() and return -1 with errno set to EBUSY in case the file descriptor is still in use. Update #3132.
* libio: LIBIO_GET_IOP() LIBIO_GET_IOP_WITH_ACCESS()Sebastian Huber2017-09-151-3/+1
| | | | | | | | | Replace rtems_libio_check_fd(), rtems_libio_iop(), rtems_libio_check_open() and rtems_libio_check_permissions() combinations with new LIBIO_GET_IOP() and LIBIO_GET_IOP_WITH_ACCESS() macros. Update #3132.
* libcsupport: Doxygen enhancement GCI task #6Alex Ivanov2012-12-111-2/+10
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992212
* Filesystem: Rename definesSebastian Huber2012-03-131-1/+1
| | | | | | | | | | | | | | | o Removed RTEMS_LIBIO_PERMS_SEARCH. o Renamed RTEMS_LIBIO_PERMS_READ in RTEMS_FS_PERMS_READ. o Renamed RTEMS_LIBIO_PERMS_WRITE in RTEMS_FS_PERMS_WRITE. o Renamed RTEMS_LIBIO_PERMS_EXEC in RTEMS_FS_PERMS_EXEC. o Renamed RTEMS_LIBIO_FOLLOW_HARD_LINK in RTEMS_FS_FOLLOW_HARD_LINK. o Renamed RTEMS_LIBIO_FOLLOW_SYM_LINK in RTEMS_FS_FOLLOW_SYM_LINK. o Renamed RTEMS_LIBIO_MAKE in RTEMS_FS_MAKE. o Renamed RTEMS_LIBIO_EXCLUSIVE in RTEMS_FS_EXCLUSIVE. o Renamed RTEMS_LIBIO_ACCEPT_RESIDUAL_DELIMITERS in RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS. o Renamed RTEMS_LIBIO_REJECT_TERMINAL_DOT in RTEMS_FS_REJECT_TERMINAL_DOT.
* Filesystem: Reference counting for locationsSebastian Huber2012-03-131-44/+32
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01.
* 2011-07-22 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-07-221-7/+1
| | | | | | | | | | | PR 1839/filesystem * libcsupport/include/rtems/libio_.h, libcsupport/src/fchdir.c, libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c, libcsupport/src/fsync.c, libcsupport/src/ftruncate.c, libcsupport/src/read.c, libcsupport/src/readv.c, libcsupport/src/write.c, libcsupport/src/writev.c: Some calls did not return proper status for permission errors or incorrectly permissions at all.
* 2010-07-01 Jennifer Averett <Jennifer.Averett@OARcorp.com>Jennifer Averett2010-07-011-8/+0
| | | | | | | | | | | | | | | | | | | | | * libcsupport/src/chdir.c, libcsupport/src/chmod.c, libcsupport/src/chown.c, libcsupport/src/close.c, libcsupport/src/eval.c, libcsupport/src/fchdir.c, libcsupport/src/fchmod.c, libcsupport/src/fchown.c, libcsupport/src/fcntl.c, libcsupport/src/fdatasync.c, libcsupport/src/freenode.c, libcsupport/src/fstat.c, libcsupport/src/fsync.c, libcsupport/src/ftruncate.c, libcsupport/src/ioctl.c, libcsupport/src/link.c, libcsupport/src/lseek.c, libcsupport/src/mknod.c, libcsupport/src/mount.c, libcsupport/src/open.c, libcsupport/src/read.c, libcsupport/src/readlink.c, libcsupport/src/readv.c, libcsupport/src/rmdir.c, libcsupport/src/stat.c, libcsupport/src/statvfs.c, libcsupport/src/symlink.c, libcsupport/src/unlink.c, libcsupport/src/unmount.c, libcsupport/src/write.c: Removed filesystem checks for NULL methods checks from the main posix rountines. These are now required to have at a miminum default routines in the tables.
* 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-281-1/+1
| | | | | | | | | * libcsupport/src/__brk.c, libcsupport/src/__gettod.c, libcsupport/src/__times.c, libcsupport/src/fchdir.c, libcsupport/src/ftrylockfile.c, libcsupport/src/getpwent.c, libcsupport/src/gxx_wrappers.c, libcsupport/src/libio_sockets.c, libcsupport/src/pipe.c: Use rtems_set_errno_and_return_minus_one() where it was missed before.
* 2009-06-12 Chris Johns <chrisj@rtems.org>Chris Johns2009-06-121-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c: Update comments. * libblock/src/bdpart.c, libblock/src/ide_part_table.c: Get the device from the rdev field of the stat buf. * libcsupport/include/rtems/libio.h: Add a path length to evalpath handler. Add parent locations to rmmod and unlink handlers. * libcsupport/include/rtems/libio_.h: Add a path length to rtems_filesystem_evaluate_path. Add rtems_filesystem_evaluate_relative_path, rtems_filesystem_dirname, and rtems_filesystem_prefix_separators. Remove rtems_filesystem_evaluate_parent. * libcsupport/src/base_fs.c, libcsupport/src/chdir.c, libcsupport/src/chmod.c, libcsupport/src/chown.c, libcsupport/src/chroot.c, libcsupport/src/fchdir.c, libcsupport/src/link.c, libcsupport/src/mount.c, libcsupport/src/open.c, libcsupport/src/privateenv.c, libcsupport/src/readlink.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devstat.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/ioman.c, libfs/src/pipe/pipe.c, libmisc/fsmount/fsmount.c, libnetworking/lib/ftpfs.c: Add the length parameter to the eval call. * libcsupport/src/eval.c: Add rtems_filesystem_prefix_separators, rtems_filesystem_dirname, rtems_filesystem_evaluate_relative_path. Add the length parameter to the eval call. * libcsupport/src/rmdir.c: Find the parent pathloc then the node pathloc from that node. Remove the call to find the parent given the node pathloc. * libcsupport/src/stat.c: Add the length parameter to the eval call. Set the device into the rdev field. * libcsupport/src/unlink.c: Find the parent pathloc then the node pathloc from that node. Remove the call to find the parent given the node pathloc. * libfs/src/dosfs/fat.c, libfs/src/dosfs/msdos_format.c: Get the disk device number from the stat rdev field. * libfs/src/dosfs/msdos.h: Add the length parameter to the eval call. Add the parent pathloc to the rmnod handler. * libfs/src/dosfs/msdos_dir.c: Add the parent pathloc to the rmnod handler. * libfs/src/dosfs/msdos_eval.c: Add the length parameter to the eval and token call. * libfs/src/imfs/imfs_directory.c: Add the parent pathloc to the rmnod handler. * libfs/src/imfs/imfs_fchmod.c: Do not test the mode flags for only the allowed flags. Add the missing flags spec'ed in the POSIX standard. * libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_rmnod.c, libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/memfile.c: Add the parent node. Currently ignored in the IMFS. * libfs/src/imfs/imfs_stat.c: Return the device number in the rdev field. * libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_symlink.c : Add the length parameter to the token call. * libfs/src/nfsclient/src/nfs.c: Add the length parameter to the eval call and parent node to the rmnod and unlink command. * libmisc/shell/internal.h: Remove the libc mounter decl to make public. * libmisc/shell/main_mount.c: Add support for hooking external mount support for new file systems. * libmisc/shell/shell.h: Add helper functions for the mount command.
* Remove stray white spaces.Ralf Corsepius2004-04-181-5/+5
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/chain.h, include/clockdrv.h, include/console.h, include/iosupp.h, include/rtc.h, include/spurious.h, include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h, include/rtems/termiostypes.h, include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h, include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c, src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c, src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c, src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c, src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c, src/fcntl.c, src/fdatasync.c, src/fpathconf.c, src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c, src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c, src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c, src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c, src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c, src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c, src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c, src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c, src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c, src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c, src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c, src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c, src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for license changed.
* 2002-12-26 Till Straumann <strauman@slac.stanford.eduJennifer Averett2002-12-261-2/+18
| | | | * src/fchdir.c - PR302 fix violation of FS node object copy semantics
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-3/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/libio_.h: Remove set_errno_and_return_minus_one. * libc/cfsetispeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/cfsetospeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chown.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chroot.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/closedir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/eval.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fdatasync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fpathconf.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fstat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fsync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ftruncate.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/getdents.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ioctl.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/link.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/lseek.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/mknod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/open.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/read.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/readlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/rmdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/stat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/symlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/tcsetattr.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/telldir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname_r.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unmount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/utime.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/write.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one.
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+4
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-2/+2
| | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
* Patch from Chris Johns <cjohns@cybertec.com.au> to add fchdir()Joel Sherrill2000-06-301-0/+69
functionality to libc and update TODO.
