2001-01-08 | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+3 | |
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | |||||
2000-11-01 | 2000-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files. | |||||
1999-12-13 | Added RTEMS_IO_ERROR. | Joel Sherrill | 1 | -0/+1 | |
1998-08-31 | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1 | -4/+2 | |
I think I figured out why rtems_panic was locking up instead of shutting down the executive and returning to the code that called boot_card(). Later on there is code to print some messages on the standard error stream, a recursive call back to rtems_verror (through rtems_error) and finally a call to _exit(). I think that the _Thread_Disable_dispatch() is preventing the final context switch back to the boot_card() code. Does this sound right to you? | |||||
1998-01-23 | Solaris port updates from Chris Johns | Joel Sherrill | 1 | -5/+7 | |
1996-04-22 | updates from Tony Bennett | Joel Sherrill | 1 | -3/+0 | |
1996-03-06 | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 1 | -0/+1 | |
from the application code, this file required more visibility than is given by default to application code. | |||||
1996-01-15 | Split error handler into its own directory. | Joel Sherrill | 1 | -1/+1 | |
1996-01-15 | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1 | -8/+7 | |
1995-09-29 | all targets compile .. tony's patches in place | Joel Sherrill | 1 | -1/+1 | |
1995-09-11 | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1 | -2/+2 | |
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | |||||
1995-08-17 | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1 | -0/+212 | |
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables |
