path: root/cpukit/libcsupport/src/error.c (follow)
* Added RTEMS_IO_ERROR.Joel Sherrill1999-12-131-0/+1
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-08-311-4/+2
| | | | | | | | | | | | | | I think I figured out why rtems_panic was locking up instead of shutting down the executive and returning to the code that called boot_card(). Later on there is code to print some messages on the standard error stream, a recursive call back to rtems_verror (through rtems_error) and finally a call to _exit(). I think that the _Thread_Disable_dispatch() is preventing the final context switch back to the boot_card() code. Does this sound right to you?
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-5/+7
* updates from Tony BennettJoel Sherrill1996-04-221-3/+0
* As part of reducing visibility into rtems and hiding the .inl filesJoel Sherrill1996-03-061-0/+1
| | | | | from the application code, this file required more visibility than is given by default to application code.
* Split error handler into its own directory.Joel Sherrill1996-01-151-1/+1
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-8/+7
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-2/+2
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+212
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
