path: root/cpukit/libcsupport/src/error.c (follow)
* sapi: New implementation of rtems_panic()Sebastian Huber2017-11-221-15/+0
| | | | | | | | | | | | The previous rtems_panic() implementation was quite heavy weight. It depended on _exit() which calls the global destructors. It used fprintf(stderr, ...) for output which depends on an initialized console device and the complex fprintf(). Introduce a new fatal source RTEMS_FATAL_SOURCE_PANIC for rtems_panic() and output via vprintk(). Update #3244.
* libcsupport: Avoid Giant lock in rtems_verror()Sebastian Huber2015-05-191-1/+1
* score: Change debug helper functionsSebastian Huber2014-02-121-42/+0
| | | | | | | | Rename rtems_internal_error_description() to rtems_internal_error_text(). Rename rtems_fatal_source_description() to rtems_fatal_source_text(). Rename rtems_status_code_description() to rtems_status_text(). Remove previous implementation of rtems_status_text().
* Expose rtems_verror()Nick Withers2013-08-151-1/+1
* PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__Sebastian Huber2013-08-081-7/+0
* score: Create thread implementation headerSebastian Huber2013-07-261-0/+1
| | | | | | | | Move implementation specific parts of thread.h and thread.inl into new header file threadimpl.h. The thread.h contains now only the application visible API. Remove superfluous header file includes from various files.
* score: Merge sysstate API into one fileSebastian Huber2013-07-241-0/+1
* libcsupport: Doxygen enhancement GCI task #4Alex Ivanov2012-12-111-50/+5
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/8009205
* 2011-01-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-01-041-1/+6
| | | | | | * libcsupport/src/error.c: Scheduler Simulator compilation always defines __RTEMS_VIOLATE_KERNEL_VISIBILITY__. So avoid redefinition warning.
* 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-281-119/+116
| | | | | | * libcsupport/include/rtems/error.h, libcsupport/src/error.c: Clean up so rtems_panic() can be a noreturn method. This eliminates some unreachable and thus untestable code.
* Reflect having introduced rtems_error_code_t.Ralf Corsepius2009-10-121-2/+2
* Remove hpux9 anachronism.Ralf Corsepius2009-01-051-5/+0
* 2008-08-20 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-08-201-29/+29
| | | | | | * libcsupport/src/error.c, libmisc/dummy/dummy.c, rtems/src/rtemsobjectgetapiclassname.c, rtems/src/rtemsobjectgetapiname.c: Add 0 for missing initializers.
* Added const qualifier to various pointers and data tables toThomas Doerfler2008-05-271-1/+1
| | | | | | reduce size of data area. IMFS: Fixed creation of symbolic links to avoid a compiler warning. DOSFS: Use LibBlock instead of read() to read the boot record.
* 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-091-1/+3
| | | | | * libcsupport/src/error.c, sapi/include/rtems/config.h: Do not reference _Configuration_MP_table if multiprocessing is disabled.
* 2007-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-01-091-3/+0
| | | | | * libcsupport/src/error.c: rtems_progname is no longer defined in the BSP startup since it never held a meaningful value.
* include and use inttypes.h.Ralf Corsepius2006-01-101-2/+2
* Remove stray white spaces.Ralf Corsepius2004-04-181-8/+8
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-231-1/+1
| | | | | | | | | | | | | | | | | | * libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/ringbuf.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c, libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c, libcsupport/src/error.c, libcsupport/src/libio.c, libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c, libcsupport/src/no_libc.c, libcsupport/src/termios.c, libcsupport/src/termiosreserveresources.c: Convert to using c99 fixed-size types.
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+3
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* Added RTEMS_IO_ERROR.Joel Sherrill1999-12-131-0/+1
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-08-311-4/+2
| | | | | | | | | | | | | | I think I figured out why rtems_panic was locking up instead of shutting down the executive and returning to the code that called boot_card(). Later on there is code to print some messages on the standard error stream, a recursive call back to rtems_verror (through rtems_error) and finally a call to _exit(). I think that the _Thread_Disable_dispatch() is preventing the final context switch back to the boot_card() code. Does this sound right to you?
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-5/+7
* updates from Tony BennettJoel Sherrill1996-04-221-3/+0
* As part of reducing visibility into rtems and hiding the .inl filesJoel Sherrill1996-03-061-0/+1
| | | | | from the application code, this file required more visibility than is given by default to application code.
* Split error handler into its own directory.Joel Sherrill1996-01-151-1/+1
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-8/+7
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-2/+2
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+212
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
